Extreme stack no management access
  • Problem
  • Updated 1 month ago
  • Solved
I need help with configuring external access to my Extreme stack. The stack consists of X450e-48p (master), X650-24x (secondary).
I need help with making the vlan IP accessable from the internet. I have tried everything and cannot get the switch to allow any traffic at all on these IPs. ping returns destination unreachable.
Here is my show vlan:
Slot-1 x.4 # show vlan
Name            VID  Protocol Addr        Flags                Proto  Ports  Virtual
        Active router
        /Total
Default         1    x.xx.xxx.88    /26  -----------T----------- ANY    11/18  VR-Default
Internal        4092 xx.x.x.2    /24  ----------------------- ANY    4 /5   VR-Default
iSCSI           4094 xx.x.xx.2    /24  ----------------------- ANY    3 /5   VR-Default
Mgmt            4095 xxx.xxx.xx.4   /24  ----------------------- ANY    1 /1   VR-Mgmt
Unused          4091 ------------------------------------------- ANY    0 /38  VR-Default
Ping returns nothing from within the switch:
Slot-1 x.5 # ping 8.8.8.8
Ping(ICMP) 8.8.8.8: 4 packets, 8 data bytes, interval 1 second(s).
Packet transmit error; Destination unreachable
--- 8.8.8.8 ping statistics ---
0 packets transmitted, 0 packets received, 0% loss
round-trip min/avg/max = 0/0/0 ms
The mgmt IP is inaccesable from the internet via all protocols; ssh, telnet and web. All of these protocols are enabled globally on the switch.
The iproutes for VR-Mgmt are:
Slot-1 x.7 # show iproute vr vr-mgmt
Ori  Destination        Gateway         Mtr  Flags        VLAN       Duration
#d   xxx.xxx.xx.0/24    xxx.xxx.xx.4    1    U------um--f Mgmt       0d:7h:53m:29s
IP stats on the mgmt interface seem to be receiving packets, but not sending anything:
Slot-1 x.11 # show ipstats mgmt
Router Interface on VLAN Mgmt
     inet xxx.xxx.xx.4 netmask 255.255.255.0 broadcast xxx.xxx.xx.255
     Stats:  IN         OUT
          37374           0 packets
        3854762           0 octets
            311           0 Mcast pkts
          12183           0 Bcast pkts
              0           0 errors
          23153           0 discards
              0             unknown protos
The router for my management IP can be pinged from my office connection:
Pinging xxx.xxx.xx.1 with 32 bytes of data:
Reply from xxx.xxx.xx.1: bytes=32 time=36ms TTL=249
Reply from xxx.xxx.xx.1: bytes=32 time=63ms TTL=249
However, from the switch it does not ping:
Slot-1 x.13 # ping xxx.xxx.xx.1
Ping(ICMP) xxx.xxx.xx.1: 4 packets, 8 data bytes, interval 1 second(s).
The same happens with the VR-Default vr. It's IP address is also inaccessable, however is accessable from servers connected to the Default vlan.
Any help would be greatly appreciated, I am at a loss as to how to get the management port accessable from the internet.
Thanks.
Photo of Michael Goodliffe
Michael Goodliffe
  • 670 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
yes it is the Master switch. How were you connecting in the MGMT port to the network.
I see that the MGMT port was set xxx.xxx.xxx.xx4 is it able to ping anything on that subnet?  Can you use fake IP Address and show me what the subnets are on your VLANs?
for example
Default         1    10.1.5.88    /26  -----------T----------- ANY    11/18  VR-Default
Internal        4092 10.3.4.2    /24  ----------------------- ANY    4 /5   VR-Default
iSCSI           4094 192.168.1.2    /24  ----------------------- ANY    3 /5   VR-Default
Mgmt            4095 192.168.10.4   /24  ----------------------- ANY    1 /1   VR-Mgmt
Thanks
P
