Extreme switch restarted..Working fine with no issues..But why it is restarted..?
  • Problem
  • Updated 4 years ago
I have a x-460-48t switch and it got restarted once.Now itis working fine.I doesnt have any logs at the time of issue but captured logs post restart..Can anyone help me out.It shows below error messages on logs.
07/29/2014 05:14:58.68 <Warn:Kern.Card.Warning> Slot-1: shid_eeprom_read:line 4522:I2C I/O operation failed. Err 14507/29/2014 05:14:58.68 <Warn:Kern.Card.Warning> Slot-1: select_mux:line 250:I2C I/O operation failed
07/29/2014 05:14:58.68 <Warn:Kern.Card.Warning> Slot-1: shid_write_ZL30142_reg:line 9510:I2C I/O operation failed. Err 145
Photo of ComraDe
ComraDe
  • 510 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Please contact GTAC, you may need to upgrade EEPROM.
Photo of Jason
Jason, Employee
  • 294 Points 250 badge 2x thumb
Please provide this item when calling in for support
show debug system-dump
Show tech
Photo of ComraDe
ComraDe
Hi Jason,
Does it make any service impact if i execute the command
#show debug system-dump
Photo of Jason Parker
Jason Parker, Employee
  • 2,918 Points 2k badge 2x thumb
no impact with command
Photo of ComraDe
ComraDe
Thanks.......jason...
Photo of ComraDe
ComraDe
Thanks for your time sumit...Glad to hear from everybdy....
Sumit Tokle, Alum
If you are running base software version or unsupported software(EXOS 12.5) then please upgrade the switches and then see if you are facing any issues.
Photo of ComraDe
ComraDe
Thanks sumit.... :)
Photo of John Kaftan
John Kaftan
  • 810 Points 500 badge 2x thumb
Take a look in the release notes of all of the versions of FW between what is current and where you are now.  Do a search for "reset" or "eeprom" to see if you can find the specific error in the release notes of what was fixed with that particular release.
Chances are the issues has been discovered and there has been a fix already.
John
Photo of ComraDe
ComraDe
Thanks John...Its gud to hear that there is alws some persons here to help us.....I will check the release notes as well...
