extremePortEgressRateLimitTable-implementation in firmware
Lars_Kristian
Anyone know when the extremePortEgressRateLimitTable snmp-value is going to be implemented?
I need it 🙂
We use rate-limit egress on switchports to control bandwidth, and policy+meters on ingress..
Ideally, I need a way (through snmp) to query many switches to make sure all ports have these settings...
2 REPLIES 2
M_Nees
Contributor III
maybe newer json API (direct) on the switch may help ?(never used or tested)
Chalasani__Shad
Unfortunately we don't have any plans at this time but will add it to the roadmap list for tracking it. Thanks.
