facing wifi connectivity issues
  • Question
  • Updated 2 years ago
  • Answered
I facing every day connectivity issue with access point some time user can access the internet some time not. what to trouble shoot. APs 3705i version
Photo of Sikander Shah
Sikander Shah
  • 712 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Philipp Josten
Philipp Josten
  • 162 Points 100 badge 2x thumb
Hi Mister Shah,
first you have to troubleshoot if the wlan signal is aborted to the client or not.
If there is no connection interupption on your client, then you have to look in your network (guest portal, network traffic, firewall, internet connection).you can capture the traffic from that AP eth interface by configuring the AP at the controller "real Capture". (see picture)
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
To complement Josten suggestion please see article https://gtacknowledge.extremenetworks.com/articles/How_To/Using-Real-Capture-to-capture-wireless-tra... for details on how to capture traffic from an AP using wireshark tool.
What is the status of wireless connectivity of the MUs when they cannot access the internet? Are users still connected to wireless? Can they ping their default gateway? Only traffic to the internet is affected? Does the problem happens when they roam from one AP to another? Trying to identifying the situation when there is a failure will help with the troubleshooting.
Sikander Shah
hi AG, (1) yes connected but not pinging the default gateway. (2) No users are not roaming but internet is affected.
I  had same issue, I upgraded my controller 7 times to resolve the issue to some extent. Currently we are running on 9.21.8.x .
Still I have dis connectivity issues to some extent.
1) I would suggest upgrade to 9.21.8.x or higher. Better to upgrade to 10.x.x.x
2) If issues are with apple devices ensure probe suppression and force disassociation are enabled
3) enable only g/n , remove b from radio settings
4) ensure WLAN timeout/session periods are configured as per recommended values.
5) ensure Under the Bridged at AP topology,  ARP Proxy option is unchecked or disabled.
Hope the above will help, rest is upto extreme they should come out will a resolution. I am strugling from past 1 year to resolve the issue completely.
Photo of Raffi
Raffi, Employee
  • 1,598 Points 1k badge 2x thumb
Are these both the same issue? Sikander's issue sounds like for some reason client's show as they are connected to the wireless medium, but are not able to pass traffic. In Saiprasad's issue I see "disconnectivity issues to some extent". Does that mean clients are actually dropping off the network and then reconnecting again?
Troubleshooting intermittent issues is always difficult, especially with a medium that is invisible to our eyes such as 802.11. That is why it is helpful to get some diagnostics to see what is happening. It is also why starting off the troubleshooting by upgrading to the latest wireless infrastructure firmware and client driver / supplicant software is always the easiest first step. This upgrading is good because it adds new functions and also resolves known issues and is relatively quick and painless. The next step is to deep dive into troubleshooting.
First suggestion in "intermittent troubleshooting" is to get to users who are having issues and to have a dialogue with them to understand what happened to them ( ie a non technical user will thinks they have a wireless issue...wireless not working... because some client / server application had an issue, but they were actually connected to the wireless just fine ! ).  You can actively go about the environment with your own equipment, using the network with your own equipment to hopefully catch something happening, or to conclude that the network is working pretty well !  If the opportunity presents itself to troubleshoot, then things to look for is to search for the problem client's mac on the controller gui reports, like reports->wireless clients by ap. Take a screenshot, it will show you what ap you are on, what signal the ap sees the client at, what radio you are on. Then you can navigate to that ap under the wireless aps section, and enable remote capture. You can also get the aps current ip from the static tab under the aps config. Then you can point your wireshark and do a capture on wifi0 for 5ghz radio, wifi1 for 2.4ghz radio, and eth0 for the ap's wired Ethernet port. If you have time, best to capture the wireless and wired quickly while the client is doing something like pinging the default gateway, and something off the network like google, 8.8.8.8. AG posted the link to aid in using the fantastic realcapture tool previously.
You could also check for any messages for the client mac under controller->logs->station events, pasting the client mac in the search window.
You can collect the ap trace file, log->ap traces->select ap and retrieve trace.
For windows client's can check and verify that its drivers are updated and windows power management for the wireless interface is off for maximum performance.
For mac client's can use the wireless diagnostics utility to do wireless packet captures, and to monitor wifi connection. When there is an issue the monitor tool will generate a zip file with files that can help identify what the problem was.
Verify if all users on the ap are having issues, or just one client.
Also, under wlan, make sure the the pre/post and session timeouts make sense ( ie pre=5 post=30 and session=0 ), otherwise you'll have ton's of user sessions that are stale on the controller.
Use radio preference group to push 5ghz capable clients to use 5ghz, a much better band with more channels and less interference.
It can turn out that in 10 complaints, each case is different...ie one user connected hanging on to a far away ap with poor signal because the client decides not to roam to an ap closer. One case could be a client with pwr mgmt. enabled. One trace could show the client probe req, and probe rsp coming back but the client not proceeding to associate, etc. On the surface they would all look the same.
