failed k-10 blade
  • Problem
  • Updated 4 years ago
  • Solved
I have a K-12 switch and one of the blades stopped working. So I replaced the blade and the status light did not come on, and none of the ports on that blade work. What could be the problem?
Photo of Ako Singletary
Ako Singletary
  • 240 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Hello,
Is the K series showing messages in the logging buffer for this slot?
(Edited)
Photo of Doug Hyde
Ako,
Just following up. Are you still having issues with the K?
Ako Singletary
Nope, it seemed to have cleared-out working as it should now. Thanks!
Photo of Doug Hyde
Good news, keep us posted if things change. Typically that logging buffer is a great place to go on the K to see why the slot is failing. You can paste the error message into our GTAC Knowledge Site. If we know about the error, it should give you recommendations on next steps.
