Fan Numbering in the SecureStack Series
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 10819
Products
SecureStack C3, C2, B3, B2, A2; firmware all
Goals
Meaning of the "Fan 0 has failed." or "Fan 1 has failed." reference within syslog, logging buffer, and serial console messages generated upon failure of a fan; for example:
<162> OCT 06 10:13:51 10.156.133.245-2 SIM[221852416]: bootos.c(1588) 1173 %%
Fan 0 has failed.
Meaning of the "Fan 1 has failed." or "Fan 2 has failed." reference within current.log messages (5743) generated upon failure of a fan; for example:
<162> MAY 18 17:31:00 10.17.99.21-1 SIM[147737568]: bootos.c(867) 40731958 %%
Fan 2 has failed.
Meaning of the "Fan1-status" and "Fan2-status" references seen in the output of a 'show system' query; for example:
Fan1-Status                        Fan2-Status
Installed and Not Operating Ok
Solution
With C3/C2/B3/B2 firmware x.02.01.0006 and lower, and all A2 firmware:
    Syslog 'Fan 0' (current.log 'Fan 1', system 'Fan1') is any of the fans located on the rear of the SecureStack unit near the stacking cables.
      Syslog 'Fan 1' (current.log 'Fan 2', system 'Fan2') is any of the fans located on the sides of the unit.
    With C3/C2/B3/B2 firmware x.02.02.0009 and higher:
      Syslog 'Fan 1' (current.log 'Fan 1', system 'Fan1') is any of the fans located on the rear of the SecureStack unit near the stacking cables.
        Syslog 'Fan 2' (current.log 'Fan 2', system 'Fan2') is any of the fans located on the sides of the unit.
      Photo of FAQ User
      FAQ User, Official Rep
      • 13,620 Points 10k badge 2x thumb
      Posted 5 years ago
      There are no replies.
