Fast failover and AP poll timeout
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hi Guys,
I got a little confused regarding the times when setting up fast failover and AP poll timeout.
from Wireless Lab Guide: fast failover 2 seconds and poll timeout to 3 or 4 seconds
from GTAC Knowledge: fast failover 10 seconds and poll timeout to 15 seconds
What are the recommended values?
Does it matter where the APs are located - in our case the controller is in Europe and the APs are in China??
Regards,
Stephan
Photo of Stephan
Stephan
  • 464 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,136 Points 20k badge 2x thumb
I would go with the 10/15 rule if you don't have voice traffic. Are you configuring the solution for B@ap?
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
What do you go with if you do have voice traffic?
Photo of Doug Hyde
The manual suggest...To achieve ideal availability behavior, you must set the Poll Timeout value for all APs to 15 seconds,
and the Detect link failure on the IdentiFi Wireless Appliance > Availability screen to 10 seconds. You can cut that in half for voice.
Photo of Stephan
Stephan
Hi Doug,
thank you for your answer. Yes, we also configuring this B@ap.
