Feature similar to Cisco IP SLA and track
  • Question
  • Updated 2 years ago
  • Answered
Hi
I new in Extreme stuff. Pls advise how can I configure to change default route based on ping check. Something similar to cisco ip lsa and tracking. Flow redirect doesn't meet my requirements , I need to change default route because it is propagated by ospf to others switches.
Thanks in advance
Photo of Pawel Zwierzynski
Pawel Zwierzynski
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,942 Points 1k badge 2x thumb
You can use the keyword "protection ping"
e.g.
configure iproute add 100.0.0.0/24 1.2.3.4 protection ping
configure iproute add 100.0.0.0/24 1.2.3.5 protection ping
if both gateways anwer you have a l3 load balancing.
Regards
André
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
The "ping" protection on a static route is supported in 16.1, 21.1 or later. You can modify parameters (interval and number of miss) for the ping protection with the following command.
# configure iproute protection ping interval <sec> miss <number of miss>
If you have an earlier EXOS you can still use upm:
Below a script, that does similar by disabling an Port to an ISP:
create upm profile pingtest
set var primeport 31
# the port of the primary ISP router
set var target 10.2.100.100
# the target IP address used to determine the health of connectivity to the
# primary ISP
set var CLI.OUT 0
ping count 1 vr vr-default $target
set var pinglist $TCL(split ${CLI.OUT} "\n")
delete var CLI.OUT
set var pingrespln $TCL(lsearch -glob $pinglist *received*)
set var pingresp $TCL(lindex $pinglist $pingrespln)
set var pingnorcv $TCL(regexp -nocase {0 packets received} $pingresp)
if ($pingnorcv == 1) then
   disable port $primeport
   create log entry "Failed Uplink "
   disable upm profile pingtest
endif
create upm timer pingtest
configure upm timer pingtest profile pingtest
configure upm timer pingtest after 1 every 1
Regards
André
Pawel Zwierzynski
Thank you for responses. I have ExtremeOS 16.1.2.14, protection ping is available from 16.1.3. By the way it isn't meet requirements completly, I want to ping host which I can define.
Andre thank you for the script. What in case that route became available?
