Fiber connection from switch to server-No Link
  • Question
  • Updated 2 years ago
  • Answered
Hello Everyone,
I have an Enterasys B5K124-48P2 with a FTLX8571D3BCL-EX SR SFP+ module installed in port 49.
On the other end is a Lenovo 650 with an Intel x520 card and an Intel FTLX8571D3BCV-IT module.
I am using MM 50/125 Tripp Lite patch cable.
The switch recognizes the SFP and no issues jump out that I can see.  The card in the server appears to be working fine as well.  I did manually set the speed on the server card to 10GB instead of Auto.
Added bonus, I'm pretty new to Extreme/Enterasys and my knowledge of fiber is weak.
I'm not getting a link light between the two of them.  Windows reports the cable is unplugged, and the switch is giving me "operator down".
Can anyone give me an idea as to what my next steps would be?
Thanks
Photo of Rich Plummer
Rich Plummer
  • 100 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Roger Green
Roger Green
  • 200 Points 100 badge 2x thumb
what is your fiber protocol ? LX, SX, etc.
Rich Plummer
I "believe" it's SX.  Both of those transceivers are the short run over MM.  I'm not sure where else I verify that..
Roger Green
check the hardware itself. if its SX, make sure both devices run that
Roger Green
fiber, sfp protocol
Photo of Rich Upshaw
Rich Upshaw
  • 1,140 Points 1k badge 2x thumb
I would let your NIC on the server autonegotiate first.  It should negotiate at 10G.
I was going to tell you to force the port on the B5 to 10G but I'm not sure you can do that at that rate.  I'm only seeing options for 1000.
Roger Green
I disagree. auto speed/dupex rarely works. specify on both ends, switch and nic
Rich Upshaw
I was referring to his statement that he forced his server NIC to 10G.  I'd let it autonegotiate.
Also, how do you force the B switch to 10G full?
(Edited)
Rich Plummer
I think that switch only supports 10GB
CHS-MDF-B5(su)->show port status tg.1.49          Alias        Oper    Admin   Speed
Port      (truncated)  Status  Status  (bps)     Duplex  Type
tg.1.49   CHS-MDF-710  Down    Up      10G       full    SFP+
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,732 Points 2k badge 2x thumb
The 10g ports on the C5/B5 platforms are fixed.  S/K may support both 1g and 10g optics.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,486 Points 5k badge 2x thumb
Let me correct the post above:
B5K does have two ports fixed 10G.
C5K does have two ports 1G/10G = dual speed. = http://learn.extremenetworks.com/rs/extreme/images/C-Series-DS.pdf
(Edited)
I stand corrected on the C5
Rich Upshaw
Roger, might he need to flip the A and B on the fiber strands?  Just another thought.
Roger Green
valid thought Rich...what is the fiber interface type...I would assume LX connectors, so switch pairs at the LIU
  • 9,548 Points 5k badge 2x thumb
I would check "loop" connection B5K - transceiver - patch cable - transceiver - B5K.
If that works you will know that those components are good.
Good luck
Photo of EtherMAN
EtherMAN, Embassador
  • 6,960 Points 5k badge 2x thumb
Just FYI there is no "auto negotiate" for any 10 gig link... Was not part of the standard.  Also in our 6000 or so active edge interfaces going to all kinds of network devices and gear on 100/1000 connections Auto-Auto is the best for anything under 5 years old between vendors.  We have nore issues with the 5 to 10 % hard coded interfaces not coming up or coming up half duplex due to technician doing the deployment not knowing to hard code or not hard coding it correctly.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,058 Points 10k badge 2x thumb
I would extend the prefer auto-auto time frame to the last ten years, at least. ;-)
Rich Upshaw
Good info.  It's nice to see a Layer 1 discussion every once in a while :)
