filtering show command output on extreme networks x460-24t switch
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
i followed http://documentation.extremenetworks.com/exos/EXOS_All/Getting_Started/r_filtering-the-output-of-sho...
 is the output
X460-24t.5 # show vlan vlan2001  dhcp-address-allocation | include 24
^%% Invalid input detected at '^' marker.
Without piping I get
X460-24t.2 # show vlan vlan2001  dhcp-address-allocation
IP MAC State Lease Time Left
10.0.0.3 00:24:88:00:0a:b1 Assigned 0001:04:40
10.0.0.4 00:24:88:00:1d:91 Expired 0000:00:00
10.0.0.5 00:24:88:00:1a:36 Assigned 0001:47:03
10.0.0.6 00:24:88:00:1a:31 Assigned 0001:47:29
10.0.0.7 00:24:88:00:1a:12 Assigned 0001:24:13
10.0.0.8 00:24:88:00:73:25 Offered 0000:00:00
10.0.0.9 00:24:88:00:1a:46 Assigned 0001:24:11
10.0.0.10 00:24:88:00:1a:15 Assigned 0001:47:22
10.0.0.11 00:24:88:00:72:5f Assigned 0001:24:06
10.0.0.12 00:24:88:00:1a:fa Expired 0000:00:00
10.0.0.13 00:24:88:00:1a:44 Assigned 0001:51:31
10.0.0.14 00:24:88:00:15:e3 Expired 0000:00:00
10.0.0.15 00:24:88:00:1a:58 Assigned 0001:46:44
10.0.0.16 00:24:88:00:1a:1d Assigned 0001:47:20
10.0.0.17 00:24:88:00:13:c8 Assigned 0001:48:28
10.0.0.18 00:24:88:00:00:2c Assigned 0001:23:57
10.0.0.19 00:24:88:00:1b:18 Expired 0000:00:00
10.0.0.20 00:24:88:00:1a:16 Assigned 0001:24:58
10.0.0.21 00:24:88:00:02:91 Assigned 0001:12:05
10.0.0.22 00:24:88:00:72:22 Expired 0000:00:00
Another thing , is there any way to put command output in scrollable block to avoid long looking messages.
(pre and blockquote tag did nothing about enclosing content in a frame) ?
EDIT: Fixed the formatting for you  -Drew C.
Photo of sumeet
sumeet
  • 798 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Must be a bug, worked for me.  What version of code?
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
May be you are running the older code which doesn't support filtering.
Photo of Jeremy
Jeremy, Embassador
At the end where you put your pipe "|".  Right after that, if you do a ?, do you get any options or an error?
Photo of sumeet
sumeet
to Jeremy Gibbs
<pre>
X460-24t.2 #  show vlan vlan123 dhcp-address-allocation |?                                                        ^
</pre>
caret is just below pipe
How to find version of code ?
(Edited)
Photo of Jeremy
Jeremy, Embassador
show version
Photo of sumeet
sumeet
X460-24t.1 # show version
Switch      : 800321-00-09 1224G-80358 Rev 9.0 BootROM: 2.0.1.7    IMG: 12.5.4.5
PSU-1       : EDPS-300AB A-S7 800386-00-03 1224E-40092 Rev 0.0
PSU-2       :
Image   : ExtremeXOS version 12.5.4.5 v1254b5 by release-manager
          on Tue Jun 28 10:10:40 PDT 2011
BootROM : 2.0.1.7
Diagnostics : 2.10
X460-24t.2 #
(Edited)
Photo of Jeremy
Jeremy, Embassador
I don't believe that version of code supports | include / find / grep etc...
Photo of sumeet
sumeet
how can I update ?
Photo of Jeremy
Jeremy, Embassador
Go here and create an account:
https://secure.extremenetworks.com/
Use serial number :1224G-80358
Download the latest .xos and upgrade. Obviously, read all caveats and release notes.
Photo of sumeet
sumeet
ok
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
Photo of sumeet
sumeet
actually , the switch is bought by another department of company .
Don't know email id provided while buying .
Without it , I can't create account on secure extreme networks . Hence , can't download  OS image for upgrading .
