Firmware download for x450a-24t
  • 2
  • Question
  • Updated 3 days ago
  • Answered
I have recent bought an old x450a-24t from Ebay and I am trying to download the latest firmware for this switch.
I have bought this for a home lab to learn more about the xos operating system.
Can anybody tell me th best way to go about this?
Also how can I tell the level of licence applied to th switch?
Many thanks,
Pete
Photo of Peter Millard
Peter Millard
  • 210 Points 100 badge 2x thumb
Posted 10 months ago
  • 2
Photo of Drew C.
Drew C., Community Manager
  • 37,320 Points 20k badge 2x thumb
Hi Peter,
As you may know, the X450a/e series is end-of-sale and nearing its end-of-life date. Since this switch is likely not under any support contract, there aren't any "normal" ways for you to get the software for this switch. I'll contact you via email to talk about some options.
Regarding license, once you're on the CLI, all you need to do is run the command: show licenses
http://documentation.extremenetworks.com/exos_commands_16/exos_16_2/exos_commands_all/r_show-license...
Photo of Drew C.
In addition to using the switch to learn EXOS, you can use the EXOS VM. More info on our GitHub page: https://github.com/extremenetworks/Virtual_EXOS
Photo of Christopher Gray
Christopher Gray
  • 110 Points 100 badge 2x thumb
To clarify, does this mean the firmware versions applicable to older hardware are not available unless there is a support contract?
Photo of Drew C.
  • 37,240 Points 20k badge 2x thumb
That's correct, Christopher.
Christopher Gray
Interesting, so purchasing used equipment is frowned upon / used equipment cannot be updated?
Photo of Daniel Steglich
Daniel Steglich
We have bought a Summit X450a-24t quite a long time ago and I want to bring this device to a recent firmware version. We bought this device from a distributor, which seems not to exist any more. We did not received a portal login from this distributor. Can any one tell me how I can get firmware download for this device?
Daniel Steglich
And what does this mean? I can't get a firmware image?
Daniel Steglich
So buying a extreme networks device always includes the risk that if the distributor will went bankrupt, then the device will be transformed into a purple brick. That was new to me.
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
which firmware version you have for now?
Daniel Steglich
11.5.2.10 another device we are using (same story) is equipped with 12.1.1.4 we want the same version on both devices. So the 12.1.1.4 would be good (or a newer version so we equip both devices with this version).
Daniel Steglich
... I can provide serial number if that helps to get the connection between us, the distributor and the device.
