firmware download page too complicated
  • 20
  • Problem
  • Updated 5 months ago
  • In Progress
I'd like to upgrade my EMC but I don't plan to search for minutes on the download page for the right file.
Example:
I'm sorry but either I'm doing something wrong or that is the most complicated way to present firmware versions.
-Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
  • sad
Posted 10 months ago
  • 20
Photo of Bruce Garlock
Bruce Garlock
  • 612 Points 500 badge 2x thumb
I was going to post something about this as well - it does seem overly complicated to find firmware now as well.
Photo of Paul Thornton
Paul Thornton
  • 1,374 Points 1k badge 2x thumb
+1
The move to the Salesforce portal has done nothing for software downloading.  It was significantly better beforehand.
On the specific point of the EMC download, I seem to remember that the filename is very counter-intuitive too.
Paul.
Photo of Steven Lin
Steven Lin, Employee
  • 2,226 Points 2k badge 2x thumb
Currently, it's not friendly enough, Extreme  portal is new, it will be improved and optimized.
Photo of Joshua Puusep
Joshua Puusep
  • 2,264 Points 2k badge 2x thumb
Agreed.  It should at least be separated by platform.
Photo of Scott Van Artsdalen
Scott Van Artsdalen
  • 344 Points 250 badge 2x thumb
Count me in with the folks that have to spend a lot of time to find the firmware I need.  Glad to hear it will be improved.
It was more "friendly" before - so the plan to replace the download page with what we've now failed.
As far as I remember I've pointed out that shortcoming during the alpha phase of the page......
In regards to "it will be improved and optimized" - what is the ETA for that - should we "work" with that for months/years ?
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,942 Points 1k badge 2x thumb
please try the "advanced" button when searching for software - This way it was possible for me to find the new EMC images in seconds.
Cheers
André
  • 45,132 Points 20k badge 2x thumb
Fair enough, let's play around....
Search filter: advanced, ExtremeControl
Result: also non ExtremeControl files are shown, i.e. EMC, ExtremeAnalytics
Search filter: advanced, ExtremeAnalytics
Result: also non ExtremeAnalytics files are shown, i.e. EMC, ExtremeControl
In case I'd like to get the files to upgrade my whole EMC suit I'd need to know that the upgrade files end with a .bin - only then I'll get all 3 files on the first page of the search result (filter: advanced, ExtremeManagment, bin).
I'm pretty sure not everyone knows that.
Next step is to click the download link - I select the EMC link - now I get the pop-up with the "Select a Customer to Download on Behalf of" menu where I'd search the right one out of 7 pages.
After a while the download starts and now the best one.... it loads once again the main download page and all my search settings are gone.
To download now also the NAC, Purview file I need to go to thru the whole process again.
-Ron
Photo of Luis Mendes
Luis Mendes
  • 1,668 Points 1k badge 2x thumb
For download i use the menu PRODUCTS, and on product have the informations, download and others
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
This is what I have been using too.  Puts the firmware in one spot in order.
OK in case of EMC 8.0.3.46 I get a list with 32 files and I'd hover over every filename to see more details (= the full file name) and if I'm familiar with the differences I'd select the right one.
Why are there NAC .ova files small/medium/large - the controller has only one .ova and the CPU/RAM decide whether it's a small/medium/large deployment.
Photo of Volker Kull
Volker Kull
  • 1,620 Points 1k badge 2x thumb
Ron,
you put your finger finger on the key point.
The download speed is much more better since working with akamai but since I was beta tester of the new portal I recommend to use a easy way to find the files you need. I preferred the view from the existing portal.
In the case of EMC the amount of files for a single version is extremly confusing.
And Yes! the authorisation process to download more than one file is annoying !
- Coming via products to the downloads, there is no advanced option
- the advanced filter skips the search field
- you cannot see the full file description - you have to check every single file
- the file description is crazy ... (EMC.., Windows..., Linux...
there is a lot of space to make this easier !
br
Volker
Photo of Peter Kulmbrein
Peter Kulmbrein
  • 1,178 Points 1k badge 2x thumb
Hi all,
complained about exactly the same yesterday
What i did use is hovering over that "Multiple Products" text in the Product Name column and select only one of them via mouse click.
That makes the choice much smaller but nevertheless it's still too much and that hovering over the file name is annoying.
Quick and dirty enhancement would be making the columns resizable so i can see the whole filename at once. Also allowing to select how many items are displayed should be easy to implement and then allow a text search for faster finding the correct file.
There's still a lot of work to do in that section...
regards
Peter
Photo of Jeremy
Jeremy, Embassador
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 37,208 Points 20k badge 2x thumb
Let me bring this up with the IT team. I'm not sure what monitoring tools they use, but I'm seeing the slowness on the products pages here in the office as well. That's not good.
Photo of Jeremy
Jeremy, Embassador
haha.. I have used my VPN service (tunnlebear), trying various countries, regions.. etc.. Nothing helped the speed.  It seems like a poorly built database index, and it's having trouble on the backend with a massive SQL select statement.
Photo of Jeremy
Jeremy, Embassador
Drew, it's been like this for months... (I tried telling a few internal people on a phone conversation at one point).  I was a Unix SysAdmin in a past life.. and I do enjoy database stuff... It really does seem like an unoptimized database query or bad indexing.
Photo of Steven Lin
  • 2,208 Points 2k badge 2x thumb
I'm using vpn as well, because access US website from China is really a pain. After using vpn, the speed is fine, not slowly like your video. Anyway, let's see is there something back from Drew.
Photo of Drew C.
I think you're correct about the database and/or the queries being run against it not being quite "right." I'm aware that the licensing page is often abysmally slow, and I believe there's some optimization that should be done there. The products page is a new one for me... I'll make sure the right people are aware of the feedback in this thread and hopefully they can figure out how to fix this.
Volker Kull
Jeremy,
Yes, waiting, and waiting, and waiting and doing several times the same klicks are huge new features in the current portal !!!:-)
They pushed a lot of ressources in that.
br
Volker
Photo of htw
htw
  • 1,144 Points 1k badge 2x thumb
You know what would be really cool? If I could tell EMCenter to download automatically updates for selected (!)  products into EMCs local firmware repository. Since EMC uses a login, Extreme can check if I have a valid support contract and are allowed to download the file. And EMC supports proxy to get in Contact with EMC directly. We have to cope then only with firmware installation and not with searching a website. Another point: if these downloads happen automatically in the background, the download speed gets less important.
From my point of view this would be a nice thing on the roadmap which decreases necessary workamount on administrators side and marketing could promote a lesser TCO since these standard tasks are automated. :-)
Photo of Matthew Hum
Matthew Hum
  • 362 Points 250 badge 2x thumb
In the 10+ years I have been working with Atlas/Netsight/<Whatever the new name of the year is> this has kept being brought up, and I can't remember but there is some legal reason (not technical) why it isn't implemented. and I can't remember the specifics, but it is not likely to happen
Let's end the week with something positive...
This thread broke the record for the most "me too" in the forum.
Thx for all the feedback & I wish u all a great weekend,
Ron
Photo of Anton Sax
Anton Sax
  • 978 Points 500 badge 2x thumb
the old enterasys extranet was better
i also had problems to find correct exos firmwares.
this had something to do with the new portal and also i am new to exos.
the filtering is really bad
Photo of Ahmed Haroun
Ahmed Haroun
  • 888 Points 500 badge 2x thumb
I Agree ,
it was much simpler , Please do something.
Photo of SH
SH
  • 2,446 Points 2k badge 2x thumb
Hello,
is there any news about the download? I think 18 me-too show here is room for improvements.
Best regards
Stephan
