firmware upgrade for RFS4000
  • Question
  • Updated 2 months ago
  • Answered
Hello, i need to Upgrade the Wing Firmware from 5.7 to the latest because i have an AP7632 and i dont have this one in the list, what is the way to upgrade this?
Photo of Luis Mendia
Luis Mendia
  • 90 Points 75 badge 2x thumb
Posted 2 months ago
Photo of Andrew Webster
Andrew Webster
  • 1,868 Points 1k badge 2x thumb
Be sure to consult the release notes for the version you are going to.  It will explain the procedure as well as any issues you need to be aware of.
Photo of Madeline
Madeline, Employee
  • 418 Points 250 badge 2x thumb
For firmware upgrade, you may refer to the following link:
How to upgrade WiNG AP firmware via CLI using FTP server
As mentioned by Andrew, you should also check the release note to see if your current infrastructure is supported on the release that you are about to update, release note can be found here:
https://www.extremenetworks.com/support/release-notes/product/extremewireless-wing-software/
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,910 Points 4k badge 2x thumb
In my opinion, this is the simplest way to upgrade your RFS using USB thumb drive:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-downgrade-WiNG-controllers-...
Photo of Yas
Yas
  • 210 Points 100 badge 2x thumb
Hi
load Yourself the firmware image of AP7632 on your RFS 4000.
then upgrade your device.
regards
T
Photo of Yas
Yas
Hi
Or you can load the file by cli.
RFS4000#device-upgrade load-image ap7632 tftp://172.24.4.18/AP7632-5.9.1.
4-004R.img on rf-domain default
and verify with
RFS4000#show device-upgrade load-image-status
RFS4000-SANDEN(config)#show device-upgrade versions
