flap ospf after add(delete) port to(from) sharing group
  • Question
  • Updated 3 years ago
  • Answered
I use summit x670 with lacp 20g.
After add(delete) port to(from) sharing group allways ospf flapping between two x670. Why? What to do?
In the same time of L2 the traffic continues to work without stopping, flapping only osfp session.
Please help.
Photo of Anton Nekhoroshikh
Anton Nekhoroshikh
  • 192 Points 100 badge 2x thumb
  • confused
Posted 3 years ago
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
I know when you add a port to an existing LAG the complete LAG is re-initialized, if this is the only port in a vlan that could cause that IP to go down and come back up, maybe this could explain the OSPF flap ?
I know this is fixed in the latest EXOS releases, only cannot find quickly which release contains the fix.
Anton Nekhoroshikh
It would be magnificent if you found the version. Thank you.
Photo of OscarK
OscarK, ESE
From what I can find 15.6.1 and higher.
Anton Nekhoroshikh
Hmm... last recommended for x670 EXOS 15.5.4.2
What to choose from 15.6.x? :-(
Anton Nekhoroshikh
May be you know patch version for 15.5.4.2 ?
Photo of OscarK
OscarK, ESE
This was an improvement (not a bug) and these are not backported, so only 15.6 and higher are having this improvement. I would recommend using the latest patch (15.6.3.1-patch1-5 at this moment).
(Edited)
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,868 Points 5k badge 2x thumb
I believe the recommendation would be update in a day or two in the official website, as per internal update the upcoming recommended EXOS version for X670 is 15.6.3.1-patch1-5
Photo of Nikolay Chernyaev
Nikolay Chernyaev
  • 180 Points 100 badge 2x thumb
Hmm.. May be you have a decision how we can add or delete ports from LAG without ospf flapping on current software? Somthing like configure variables, hold timers, may be.. We can try it on lab.
The main problem for us that after LAG re-initialize and flap of ospf(1-2 secs) we have broken mpls-connectivity which decides only by down/up links.
We can't do that :), and we haven't 5 min for flashing new firmware without reconstruction of network
