Flexview AP stats
  • Question
  • Updated 2 years ago
  • Answered
I'm trying to create a Flexview that shows the following OID's:
dot11ExtRadioAvgNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.31
dot11ExtRadioMaxNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.32
dot11ExtRadioAvgChlOccCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.33
dot11ExtRadioMaxChlOccCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.34
These stats return correctly, however I have no way of identifying the AP's "instance".
I tried adding the apName OID to the flexview which returns the names correctly, however it also seems to prevent the stats columns from populating data.  Any Tips?  Thanks much.
Photo of Joshua Puusep
Joshua Puusep
  • 2,274 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Bob Maheu
Bob Maheu, Employee
  • 1,040 Points 1k badge 2x thumb
Hello Joshua,
Let me see if can set something up in our lab and check if there is an OID I can use to map back to that.
Photo of Bob Maheu
Bob Maheu, Employee
Hello Joshua,
I'm not sure that you will be able to do this.  I have not found an OID that I can use to map the instance needed to get the AP name.
Joshua Puusep
Okay. Thanks for checking.
Photo of Thomas, Frank
Thomas, Frank, Employee
  • 1,902 Points 1k badge 2x thumb
Have you tried using ifname?
Joshua Puusep
TYVM!  This works as intended.
Glad it does!
