For (8) x620-8t-2x in a ring, is it possible to disable stacking for the 2x ports (9 and 10) and configure these as ISL uplink ports ?
  • Question
  • Updated 1 month ago
  • Answered
For (8) x620-8t-2x in a ring configuration, is it possible to disable stacking for the 2x ports (9 and 10) and configure these as ISL uplink ports ?
Photo of Scott Landry
Scott Landry
  • 70 Points
Posted 1 month ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,072 Points 10k badge 2x thumb
not sure to fully understand the question. The ports used for stacking on the x620 are regular ethernet port by default. So, if you do not enable stacking(-support) these are regular data ports, and you can do anything usual on them.
If the question is about making a ring of MLAGs, the answer is not really.
