Forescout CounterAct as NAC for ExtremeWireless Controller
  • Question
  • Updated 1 year ago
  • Answered
Hi, someone has got experience on how to use Forescout CounterAct NAC solution with ExtremeWirleless Controller and use this NAC for Captive portal and guest registration?
Thanks
Photo of Antonio Opromolla
Antonio Opromolla
  • 2,126 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Keene, Scott
Keene, Scott, Employee NMS/GTAC
  • 1,348 Points 1k badge 2x thumb
Hello,
Are you asking if anyone has experience with integrating "Forescout CounterAct NAC solution" with Extreme NAC and Extreme Wireless?  ...or are you looking to migrate  off Foerescout and implement an Extreme NAC and Wireless solution?  Is "Forescout CounterAct NAC" a wireless controller or a NAC solution? Im not sure you can integrate two vendor's NAC solutions together but also am not familiar with Forescout.
Thank you.
Antonio Opromolla
Hi Keene, w are loking to integrate the Forescout NAC solution with a Extreme Wireless Controller.
Thanks.
Photo of Arturo Aguilar
Arturo Aguilar
  • 60 Points
Hi Antonio, Do you have the opportunity of make the integration?
Antonio Opromolla
HI Arturo, our customer at the end has not made this integration.
