forward PTPv2 packets X430-8p
  • Question
  • Updated 7 months ago
  • Answered
I'm using X430-8p, and i saw it does not support PTP. So I just want the switch to forward PTP to all port without change. my setup is HUB like configuration. with the following command:
disable learning forward-packets port all
all packets i sent are forward except of the PTPv2 packets. what should I do?
Photo of Amit Geynis
Amit Geynis
  • 70 Points
Posted 8 months ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,868 Points 5k badge 2x thumb
Hi Amit,
If you can match the packet using ACL then "redirect-port-list" can be used as action modifier and can be sent out through intended ports.
This article has the outline on how to create and configure access lists.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-and-apply-an-ACL-in-EXOS
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
I don't see a reason why the switch wouldn't forward the packets.  Is this multicast or unicast PTP?  Is there a reason you are disabling learning?
What software version are you running and what other configuration changes have been made?
(Edited)
