G-Series f/w 6.61.07.0010 Reboots if I/O Module Power Off button is pressed for 8+ Seconds
  • Article
  • Updated 4 years ago
  • (Edited)
Article ID: 14982
Products
G-Series; firmware 6.61.06.0009, 6.61.07.0010
Changes
Pressed and held for 8+ seconds (the Hardware Installation Guide recommends 5 seconds) the 'POWER OFF' button corresponding to a targeted IOM slot, in preparation for removing the IOM from that slot.
Symptoms
Unit reboot.
The current.log (5487) displays a "Task EDB BXS Resp(<address>) is suspended..." message with last reset cause "Fault(0x00000300)"; for example:
    <160>Sep 3 03:43:37 172.17.8.120-1 SIM[104439944]: hwutils.c(7536) 762 %%
      ERROR:Code exception:Watchdog no longer being serviced.
    Task EDB BXS Resp(0x7fab848) is suspended with error 2, creating file sysDmp1Sep0312.z
    <57> SEP 03 03:44:17 2012 BOOT[268430624]: bootos.c(1360) 760 %%
      Start of Code - Build:06.61.06.0009 Date:Wed Jul 25 18:47:14 2012
    <110> SEP 03 03:44:20 2012 BOOT[153225176]: edb_bxs.c(1235) 764 %%
      Last switch reset caused by Fault(0x00000300) SRR0(0x01218D08) SRR1(0x0000B030) DMISS(0x00000000) IMISS(0x00000000) DAR(0x00002264) DSISR(0x0A000000)
The sysDmp (13650) file states "Task Name: EDB BXS Resp" and the diagnostic points to "faultbias"; for example:
    Detailed exception task information
    Calling Stack:
    Task ID:        0x7fab848
    PC:                    0x1218d08
    PendQ:            0x7f5184c
    SP:                   0x7fa4df0
    0x1218d08: bfill (0x1218cbc) + 0x4c
    0x5ce30: faultbias (0x5b520) + 0x1910
    0x5f0dac: edbBxsRspTask (0x5ef044) + 0x1d68
    0x121b9c4: vxTaskEntry (0x121b968) + 0x5c
Solution/Workaround
Upgrade to firmware 6.61.08.0013 or higher.
Pre-upgrade workaround: Avoid pressing the button for longer than 6 seconds.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
