G/C3/B3-Series fw 6.61.08.0013 RPS Power Traps not Functioning
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 15095
Products
G-Series, firmware 6.61.06.0009 through 6.61.08.0013
C3-Series, firmware 6.61.06.0009 through 6.61.08.0013
B3-Series, firmware 6.61.06.0009 through 6.61.08.0013
Changes
Configured for SNMP traps ('set snmp...'), then...
removed main power while a Redundant Power Supply (RPS) is attached and running
  -or-
removed power from an attached RPS while main power is running.
Symptoms
RPS Traps are not being sent to NMS, when such traps are expected under these conditions.
Syslog messages are being correctly issued; that is, respectively:
Internal Power source is not working properly or is not present.
  -or-
External Redundant Power source is not working properly or is not present.
Solution
Upgrade to firmware 6.61.09.0012 or higher.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
