G/C/B-Series 'show' command results in "Output will be truncated" errors
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 13747
Products
G3-Series, firmware 6.42.05.0001 and lower
C5-Series, firmware 6.42.05.0001 and lower
C3-Series, firmware 6.42.05.0001 and lower
C2-Series, firmware 5.02.12.0006 and lower
B5-Series, firmware 6.42.05.0001 and lower
B3-Series, firmware 6.42.05.0001 and lower
B2-Series, firmware 4.02.12.0006 and lower
Changes
Entered a command which displays more than 1024 lines of output, including but not limited to;
show rmon stats;  -or-
show multiauth session;  -or-
show port lacp port <port-string> status detail.
Symptoms
The system displays an incomplete set of output information, with added error messages:
--More-- <space> next page, <cr> one line, <q> quit
Max number of lines in the scroll buffer reached. Output will be truncated.
Cause
This can occur when a non-default terminal length is set (e.g. 'set length 23') to limit the output of the terminal to x lines between pauses.
The 1024-line buffer used in this scenario is insufficient to store the generated command output.
Solution/Workaround
For the G-Series, upgrade to firmware 6.42.06.0008 or higher.
For the C5-Series, upgrade to firmware 6.42.06.0008 or higher.
For the C3-Series, upgrade to firmware 6.42.06.0008 or higher.
For the B5-Series, upgrade to firmware 6.42.06.0008 or higher.
For the B3-Series, upgrade to firmware 6.42.06.0008 or higher.
Release notes state, in the 'Firmware Changes and Enhancements' section:
14996   Resolved a CLI buffering issue which resulted in the following error message "Max number of lines in the scroll buffer reached. Output will be truncated". This was seen when using a non-default CLI screen length in a stacked environment.
For the C2-Series, upgrade to firmware 5.02.13.0003 or higher.
For the B2-Series, upgrade to firmware 4.02.13.0003 or higher.
15087   Resolved a CLI issue whereby displaying output exceeding 1024 lines resulted in the following error "Max number of lines in the scroll buffer reached. Output will be truncated."
Pre-upgrade workaround:
Use a port-specific version of the 'show...' command to reduce the number of output lines;
      -or-
issue the 'set length 0' command before reissuing the original 'show...' command.
The default length value of "0" results in a continuing scroll until the output data is exhausted.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
