get 'destination host unreachable' with a simple connection (ethernet cable) between a PC and server
  • Question
  • Updated 2 years ago
  • Answered
Doing a simple connection (ethernet cable) at home between a PC and server. I get 'destination host unreachable' - I have configured both Ethernet connections with static IP - both are on the same subnet.  I have the sharkwire trace output of the ping, but can't make out what's wrong. I'm short on network understanding - (a DBA)
Photo of Peter Brent
Peter Brent
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Paul Poyant
Paul Poyant, Employee
  • 3,516 Points 3k badge 2x thumb
Seems that the pinging device believes that it is not on the same subnet.
See Hub article "Troubleshooting IP Default Gateway issues".
Photo of Jan Steinbach
Jan Steinbach
  • 1,078 Points 1k badge 2x thumb
Check the ARP Cache/Table in oith Endpoints and verify the used MAC addresses.
Peter Brent
Paul,  I put a router between the two servers, but I still get host unreachable.  the 1st host has this for IPv4 Address. . . . . . . . . . . : 169.254.104.10
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 169.254.104.1
-- the 2nd host this -
IPv4 Address. . . . . . . . . . . : 169.254.104.198
Still get unreachable for 104.1 (gateway) , and for address. Still don't understand why
169.254.x.x is a "link-local" addressing scheme that can be acquired by devices unable to reach a DHCP server. Such a scheme is relatively useless in practical terms. (Read about it on the web.)
Since you say that you've statically set these devices, try using some other network such as 10.20.x.x.
Peter Brent
Thanks for your help. Sorry but I'm still not 'getting' this. I have to two machines - a PC, and a server. The PC has a wireless adaptor already for internet, etc.  I want to use a different Ethernet adaptor on a separate network, to connect directly with the Server (over Ethernet cable - no router between). What do I need to do to - ? I tried, as you said not using 169.254, instead setting static IP using 10.20.1.1 (PC) and 10.20.1.2(Server). It still does not work - Also, I'm not sure what to put for the gateway. I though assigning static IPs on the same subnet should work fine..   I really think I should train on this stuff, as it's not the first it's aggravated me to no end.. :(
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
So your PC can get to the internet but not the server?
Have you tried cutting the internet connection?
It might be getting confused and trying to reach the server through the internet...
