guest authentication with external captive portal on wired network
  • Question
  • Updated 3 years ago
i have extreme switches which are enabled with dot1x in those switches i would like to enable external capative portal authentication for guest users could you please help in the configuration for this setup
Photo of santhosh kumar
santhosh kumar
  • 134 Points 100 badge 2x thumb
  • confused
Posted 4 years ago
Photo of Azharudeen VM
Azharudeen VM
  • 80 Points 75 badge 2x thumb
can u any one help how to configure captive portal configuration wired and wireless via NAC manager
Photo of Tim DeNike
Tim DeNike
  • 110 Points 100 badge 2x thumb
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Following was my config partial infomation (for netlogin)
create vlan "Temp"
configure vlan Temp tag 1164
configure vlan Temp ipaddress
configure radius netlogin primary server x.x.x.x 1645 client-ip x.x.x.y vr VR-Default
configure radius netlogin primary shared-secret encrypted x.x.x.x
enable radius netlogin
configure netlogin vlan Temp
enable netlogin web-based
configure netlogin web-based authentication database-order radius
enable netlogin ports 13-18 web-based
configure netlogin base-url ""
configure netlogin redirect-page ""
configure dns-client add name-server x.x.x.x vr VR-Default
configure dns-client add domain-suffix x.x.x.
enable sntp-client
configure vlan Temp dhcp-address-range -
configure vlan Temp dhcp-options default-gateway
enable web http
