HA C25 identifi problem - stations by protocol and AP by channel are incorrect
  • Question
  • Updated 2 months ago
  • Answered
When using two C25 with HA, I see 46 APs up on the Master with correct pie, but for the other one with 11 APs up ... I see Nothing
Is it a refresh problem ... (after trying to disconnect, connect and rebooting the C25 : same problem)
Photo of Pascal Lurquin
Pascal Lurquin
  • 950 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,500 Points 20k badge 2x thumb
I'm pretty sure that the 11APs have the active tunnel to controller#1.
You'd release the tunnel on controller#1 in > AP > Bulk Configuration > Access Approval
- select foreign in the pull down menu on the right
- click the release button below
The APs should set the tunnel to controller#2 to active and you should see the correct statistics.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,336 Points 5k badge 2x thumb
I agree with Ron, try to look at the AP availability report and compare between controllers, this article explains how to read the report: https://gtacknowledge.extremenetworks.com/articles/Q_A/Can-you-explain-the-Access-Point-Availability-Report-on-the-IdentiFi-Controller
Pascal Lurquin
Great !
Thank you !
Photo of El Vin
El Vin
  • 100 Points 100 badge 2x thumb
       I have a problem on HA set up, the access point was successfully manage by backup controller when the primary was down. It has a tunnel connection on backup controller. However the access point were unable to broadcast the SSIDs. Do we need to manually configure the VNS on backup controller even if we "enable" the synchronization on system configuration on HA setup.
