How to configure VLAN on extreme summit X450
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hai friends, i want to configure VLAN on extreme switch what is the exact command to configure it model no is summit X450
Photo of VIGNESH PALANISAMY
VIGNESH PALANISAMY
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
You should just follow EXOS documentation. Basically you create vlan and add ports to that vlan either tagged or untagged;
create vlan test
configure vlan test tag 10
configure vlan test add ports 1-12 untagged
configure vlan test add ports 24 tagged
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
Welcome to The Hub, Vignesh!
I would also recommend that you have a look at the EXOS Quick Guide.  It covers a lot of the basics.
In addition, GTAC Knowledge is great for these types of questions.
(Edited)
Photo of Brian Anderson
Brian Anderson
  • 626 Points 500 badge 2x thumb
Don't forget to remove the vlan off of the port before you add.  Gets me almost everytime :).
Usually port is in Default
Configure vlan default delete ports <port(s)>
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Good call out Brian for those new to EXOS.
Vignesh, the idea behind the Default VLAN was that you didn't need to configure a VLAN in EXOS to use the switch.  All ports are in the VLAN Default, thus if you were looking for quick Layer-2 solution...away you go.  Didn't need to configure a VLAN.
So, as Brian rightly calls out, if your first step is to build a VLAN you first have to remove the port from VLAN default.  A quick example from GTAC Knowledge:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Which-command-is-used-to-add-ports-to-a-vlan
As Drew says....welcome to the Hub Community.  Glad you joined us.
