HAL ERROR? Slot-1: Error reading from XEN card eeprom
  • Problem
  • Updated 3 years ago
  • Solved
Does any one know what causes the following errors?
06/18/2015 14:27:51.78 <Erro:HAL.Sys.Error> Slot-2: Error reading from XEN card eeprom (1, 83)
06/18/2015 14:12:22.98 <Erro:HAL.Sys.Error> Slot-1: Error reading from XEN card eeprom (1, 83)
The errors was reported on a stacking switch running XOS 12.6.2.10-patch1-15. The stack consists if the following.
Slot-1 X650-24t  (10G8X)
Slot-2 X650-24t  (10G8X)
Slot-3 X450a-48t
Slot-4 X450a-48t
I haven't been able to find any information on this error, please HELP!
Photo of Matt Tinonga
Matt Tinonga
  • 372 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,924 Points 2k badge 2x thumb
Matt, This message may indicate that there is an issue with software reading the EEPROM or that the module is no longer detected. There may be some SMBUS messages that may accompany these messages, please feel free to share if so.
It would be necessary to rule out any layer 1 issues at this time. Please let us know if the messages are causing an outage on the stack. Re-seat the modules and or reboot the stack nodes (if possible).
Please review the following Knowledge base article for more information and contact GTAC if problems still arise:
https://gtacknowledge.extremenetworks.com/articles/Solution/timeout-waiting-for-smbus-error-log/?q=0...
Matt Tinonga
Thanks Ty, not see any other SMBUS or EEPROM messages in the log. Also this not causing any type of outage in the stack. We are seeing the error occurs at the same time each day.
06/24/2015 14:27:51.78 <Erro:HAL.Sys.Error> Slot-2: Error reading from XEN card eeprom (1, 83)
06/24/2015 14:12:22.81 <Erro:HAL.Sys.Error> Slot-1: Error reading from XEN card eeprom (1, 83)
06/23/2015 14:27:51.76 <Erro:HAL.Sys.Error> Slot-2: Error reading from XEN card eeprom (1, 83)
06/23/2015 14:12:22.81 <Erro:HAL.Sys.Error> Slot-1: Error reading from XEN card eeprom (1, 83)
I have not reboot the stack nodes. Will try to do the reboots this weekend.
(Edited)
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hi Matt,
It appears you might be running into the issue mentioned in the below article:
This is why it is only displaying on slot 1 and slot 2. According to the article a reboot will temporarily resolve the issue. Ultimately I would recommend upgrading to a recommended version of code. Here is an article where you can find recommended version of codes:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-Is-The-Recommended-Release-of-EXOS-For-My-Platform
After reviewing this document myself it appears the best version to upgrade to based on this stack would be the latest patch of EXOS 15.3.5.2 (should be patch 1-3 as of today).
I hope this helps.
Patrick Voss
Matt Tinonga
Rebooting the slot 1 & 2 stop the error message in the logs.
