Have a C 5k 24 port switch that drops packets at the 8 ping and 6.
  • Problem
  • Updated 1 month ago
Have a C 5k 24 port switch that drops packets after the 8 ping and 6.  I have IP Cameras and APS attached to the switch.  Could the drops be due to the devices installed or is there a loop.  The switch is a c5k125. Is there a command I can run to see if there is a loop or if I'm putting to much of a load on the switch.
Photo of nola saint
nola saint
  • 350 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Might be a multicast problem with the cameras - could you disable the ports to the cameras and run the test again ?!
Photo of nola saint
nola saint
I disconnected all the cameras and getting the same results.
Photo of nola saint
nola saint
If it was multicast what would that mean.
Photo of Leonardo Peixoto
Leonardo Peixoto
  • 2,722 Points 2k badge 2x thumb
Hi Nola,
It's very unlikely you are having a loop condition, but it's hard to say without more information. Try taking a look at spanning tree, just in case:
show spantree stats active
Maybe It can really be a multicast problem... In some conditions, it could flood all ports...
Check the following article to see if it helps...
 https://community.extremenetworks.com/extreme/topics/can_the_securestacks_d_g_i_series_do_igmp_snoop...
Best regards,
-Leo
