Hello. Please Help!! X460G2 is running with formware version 22.1.1.5.
  • 3
  • Question
  • Updated 4 months ago
  • Answered
My X460G2 was rebooted and upgraded to firmare version 22.1.1.5. This was intermittent about six hours. Then I rebooted again and its up. But can u help me?... What does this los ́ mean?
03/06/2017 02:10:22.37 <Noti:EPM.start> Slot-1: EPM Started
03/06/2017 02:10:22.36 <Warn:EPM.UnexpctRebootDtect> Slot-1: Booting after System Failure.
03/06/2017 02:10:22.26 <Warn:EPM.UnexpctRebootDtect> Slot-2: Booting after System Failure.
03/06/2017 02:10:22.18 <Warn:EPM.UnexpctRebootDtect> Slot-3: Booting after System Failure.
03/06/2017 02:10:21.25 <Noti:EPM.wd_warm_reset> Slot-1: Changing to watchdog warm reset mode
thanks.!!
Photo of Angel Pavon
Angel Pavon
  • 544 Points 500 badge 2x thumb
  • sad
Posted 1 year ago
  • 3
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hello Angel,
Did you pull the plug on the switches?
Angel Pavon
Hi Patrick no I didn ́t, just ther rebooted by itselve.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
To me this is something found to be the switch lost power and this is either a power cable problem or the power supplying the switch went out throwing these log message later:
<Noti:EPM.UnexpctRebootDtect> Slot-1: Booting after System Failure.
Patrick Voss, Alum
The fact that all 3 switches rebooted at the same time makes me believe that the power source needs to be looked into.
Angel Pavon
I found the problem, and yes affectively it was the power. Thanks a lot. One more cuestion.
What do you think about firmware version 22.1.1.5?
Do you know if this has some problems whith another versions?
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
Angel, that release is very new and has not received any patches yet. There are a few issues with SSH that I believed are resolved in 22.2, but it also is quite new. That shouldn't be a deterrent, but rather something to consider.  Check the release notes for each to review known issues.
Photo of Tooley, Akiko
Tooley, Akiko, Employee
  • 600 Points 500 badge 2x thumb
Please refer to the Release Notes below for 22.1 -
This EXOS version doesn't have the fix for the SSH issues: http://documentation.extremenetworks.com/release_notes/ExtremeXOS/22.1/downloads/ExtremeXOS_22.1_Rel...
Please refer to the Release Notes below for 22.2 -
This EXOS version contains the fix for the SSH issues: http://documentation.extremenetworks.com/release_notes/ExtremeXOS/22.2/downloads/ExtremeXOS_22.2_Rel...
Angel Pavon
Thanks a lot!!!! Friends.
Photo of Sylvain Perron
Sylvain Perron
  • 60 Points
Hi Angel,
I have the same problem, so what was your conclusion about the error.  Did you change the power supply? power cord?
Thanks
Sylvain
