Help with network load balancing(NLB) or stacking on x440
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
hello there, any one help me with this,as i have to x440 24port switches,i want to do network load balancing(NLB), or some1 advised me to do stacking between them ,i want to know how its done in both cases ... advace Thanks
Photo of Ali Hussain Mohammed
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Ali,
Regarding NLB, if you are referring to MS NLB, please see the article below:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-Extreme-switches-to-handl...
However, If you are trying to accomplish traffic load balancing you can use MLAG/LAG. You can find more details in the article below:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-MLAG-in-Extreme-switches
Using MLAG you will have 2 x440 switches acting as a single logical unit (not stacked).
Please let us know if you have any question.
Photo of Henrique
Henrique, Employee
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Ali,
Welcome to The Hub!  I see this topic was marked as "private" but I don't see any content here that warrants privacy.  I've changed it to "public" so others can assist if Henrique's response doesn't answer your questions.  I've also updated the topic's title to help make it a little more clear for others.
-Drew
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Ali,
For clarification, are you referring to Load balancing or Load sharing?
Our switches are not able to load balance meaning that an even amount of traffic is sent out each port in a LAG or in any other scenario. The recommendations Henrique mentioned will allow load sharing which means that the traffic is sent out ports using an algorithm that way there is no overhead or extra processing.
Please let me know if you have any questions.
(Edited)
