help with a black diamond 8810.
  • Problem
  • Updated 4 years ago
  • Solved
Hi, I can help with a black diamond 8810. what happens is I can not boot from picture 1, picture 2 that comes by default and gives errors. greetings,
Photo of Carlos Valladares
Carlos Valladares
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,826 Points 20k badge 2x thumb
Hi Carlos,
Did this problem start suddenly?  Can you share the error messages you are seeing?
You may have a corrupted installation.  It is possible to reload EXOS from the BootROM to try to recover.  You will lose any configuration files saved on the switch by doing this.
You may also have a hardware failure that requires an RMA.
I would invite you to open a case with GTAC so they can help determine if the errors are recoverable or if it will require a replacement.
-Drew
Carlos Valladares
This error throws me to boot from the 2 images.
Regards,
Photo of Drew C.
Hi Carlos,
It looks like your switch has encountered a hardware failure of some sort.  Can you please open a case with GTAC so that they can help narrow down the issue and work with you to replace the failed parts?
Carlos Valladares
Hi Drew, Might help me open a case GTAC, since I'm new to this site.
regards,
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
please call TAC and provide the serial number.
+18009982408.
+14085792826
Carlos Valladares
thank you!
