Help writing a flow redirect acl
  • 2
  • Question
  • Updated 12 months ago
  • Answered
What I am attempting to do is to push any outbound port 80 traffic (https too but not in this example) to the internet with a flow redirect command but skip if the traffic is local.  So here's what I have so far:   the ** are comments for the sake of this post.  Does this make sense?
ACL
entry Allhttp {
if {
    protocol tcp;
    source-address 10.234.0.0/16;
    destination-address 10.234.0.0/16;
    source-port 80;
then {
      Deny;     ** in essence skip
** so if not the above do this.
if {
    protocol tcp;
    source-port 80;
then {
    redirect-name ToBluecoat;
    count WebHTTP;
Photo of Dave Bogdan
Dave Bogdan
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,868 Points 5k badge 2x thumb
Hi Dave,
The rules which you have mentioned needs to be modified a bit.
Instead of "deny" using the "permit" action modifier will apply the normal forwarding logic.
All the below rules must be in same policy file.
Here is a sample.
entry HTTP_PACKETS_TO_10.234.0.0 {
If match all {
Protocol TCP;
destination-port 80;
} then {
permit;
# same subnet but matching https traffic
entry HTTPS_PACKETS_TO_10.234.0.0 {
If match all {
Protocol TCP;
destination-port 443;
} then {
permit;
entry HTTP_to_other_than_10.234.0.0/16 {
if match all {
    protocol TCP ;
    destination-port 80 ;
    source-address 10.234.0.0/16 ;
then {
    count WebHTTP;
entry HTTPS_to_other_than_10.234.0.0/16  {
if match all {
    protocol TCP ;
    destination-port 443 ;
then {
    count WebHTTPS;
Here is an article on how to configure flow redirect.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-flow-redirect
I hope this is helps!
Dave Bogdan
Perfect!! Thank you. I'll test it later this week.
