Help configuring the switch
  • Question
  • Updated 4 years ago
Where is the step by step guide that can be used to configure a switch. I keep asking and no one is helping. The pages in the guide is more than a 1000 and am i just to keep reading even when I do not understand what is to be done. Please I need someone to get in touch or provide a basic guide to help with configuring a switch and how to connect to the virutalbox which I am using to practice.
Photo of Ruthie
Ruthie
  • 408 Points 250 badge 2x thumb
Posted 4 years ago
Photo of James Reynolds
James Reynolds
  • 160 Points 100 badge 2x thumb
Photo of Jason
Jason, Employee
  • 294 Points 250 badge 2x thumb
I have placed a basic set of commands to set up a new unit ( collection of commands) hope it helps
I am assuming that you have the replacement unit and appropriate licenses
Jason
Extreme Basic Setup
Extreme Setup Guide
configure account admin
create account admin"________"
create account user "customer"
enable web http
config snmp sysname "name"
configure timezone name EST -300 autodst
config time "10 09 2008 14 10 59"
enable dos-protect (CPU DoS Protection)
disable edp ports "1-23" (disbale this on all edge ports)
show edp ports all(to test after neigboring switches are setup)
config ports "1-23" rate-limit flood broadcast 250 (for all edge ports)
config ports "1-23" rate-limit flood multicast 500 (for all edge ports)
config ports "1-23" rate-limit flood unknown-destmac 500 (for all edge ports)
config ports "1-6,10-15" display-string "portName"
config ports "23-26" auto off speed 100 duplex full
LAG Groups
enable sharing "1" grouping "1-2" lacp
show port sharing (to test)
VLAN's and Routing
config vlan default delete ports all
create vlan "voice"
config "voice" tag "200"
config "voice" ipaddress "192.168.0.1/24"
config "voice" add ports "24"
config "voice" add ports "1-23" tagged
Do the same for Data with no tagging
create a firewall vlan with no tagging as well and have all subnets with the router point to firewall vlan address
config iproute add default "router inside ip"
config iproute add "x.x.x.x/24 x.x.x.x"
enable ipforwarding
DHCP Relay if needed, Core switch only
configure bootprelay add "ip of DCHP Server" vr vr-default
enable bootprelay
show bootp (to test)
DNS
configure dns-client add name-server "ipaddress" vr vr-default
Time Sync (use 129.6.15.28 if no server)
configure sntp primary "IP of DomainController" vr vr-default
enable sntp-client
QoS (avaya ipo and CM voice example)
create qosprofile "qp5"
config diffserv exam code-point 34 qp5
config diffserv exam code-point 46 qp5
enable diffserv exam ports all
disable dot1p exam ports all
show port "2" qosmonitor no-refresh (to test QoS)
RSTPD
disable stpd s0 auto-bind vlan default
config stpd s0 mode dot1w
config stpd s0 default-encapsulation dot1d
config stpd s0 priority 4096 (core switch only for this command)
config stpd s0 add "voice" ports "all" (for an edge switch) or...x ports (dont protect servers, pbx, firewalls)
config stpd s0 add "data"..........and all other vlans
config stpd s0 ports link-type edge "1-23" edge-safeguard enable (for edge ports)
config stpd s0 ports link-type point-to-point "26" (for links to other switches)
enable stpd s0
Factory Default
unconfig switch all
switch none (from bootrom)
Updates - update non-active bank then use image _______
show switch note versions and image selected-If you are using mgmt you need vr mgmt if you are inline use vs - default.
Example:
download image IP-Address summitX-15,4,1,3.xos "Vr-Default" secondary
Download command as jason said for new code tarp for other files download image 192.168.0.90 summitX-12.3.3.6.xos vr vr-default "secondary or primary"
-If you are using mgmt you need vr mgmt if you are inline use vs - default. Download command as %For new code tarp for other files
show switch to verify
use image ____________
save
reboot, and repeat if wanted for other bank
If you aren't stacking then use QP7 instead of QP5.
Also, if you're using a voice VLAN then you won't want to disable 802.1p - assign dot1p value to QP7 and also just the voice VLAN to QP7 so that the control unit and other Voice servers are also included in the QoS policy.
Comment Edit Remove
Photo of Byzek, Yeva
Byzek, Yeva, Extreme Alumna
  • 60 Points
