Hi all! What is different between LACP or a static algorithm??? Please advice.
  • Question
  • Updated 3 years ago
  • Answered
enable sharing port 47 grouping 47,48 L2 or L3
Kindly advise.
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
Hi
Lacp is for interoperability between multiple vendors.
Lacp is Ieee standard.
Lacp can more than 8 links which can be standby
Static lag has its own limitations based on vendor.
The above config u made is static lag
Photo of Paul
Paul
Hi PARTHIBAN,
Thanks, I want to create Link aggregation between 2 Extreme Switch. Now is only 1 link connected. What is the best solution? There will be any downtime or network loop may happend?
You should have the same lag configured on the peer switch.
Once that's done u can connect both the links.
If there is a misconfiguration then there is possibility of loop .
But it's just one liner.
Also u should add necessary vlans to the master port 47 to carry traffic
Photo of Paul
Paul
Thanks PARTHIBAN,
Can you please provide the command to check after the LAG configuration done at both switches?
Is it load sharing using 2 Link or only using Master port?
And how can we prevent if Loop occur. Unplug the link and remove config? Or it will still creating a Network loop?
Please advice.
(Edited)
Photo of Paul
Paul
hi how to add necessary vlans to the master port 47 to carry traffic?
Show sharing
Then use show port 47,48 utilisation/statistics
This should tell u if the tragic is load shared.
Photo of Paul
Paul
And how can we prevent if Loop occur. Unplug the link and remove config? Or it will still creating a Network loop? thanks.
When we have right config we need not worry about loop.
But for precautions we can enable elrp.
Elrp can shutdown ports when loop is detected
Photo of Paul
Paul
Thanks PARTHIBAN,
Photo of Weda
Weda
  • 994 Points 500 badge 2x thumb
Hello Folks, Could you please  explain, what is the major difference between static and dynamic LAG? Is that only, dynamaic LAG supports different vendor switches and Static LAG supports only for same vendor switches ? Thank you very much in advance.
