hi guys what is the equivalent cisco command; spanning-tree and portfast to extreme.. Thanks in advance.
  • Question
  • Updated 12 months ago
  • Answered
Photo of Jun Papa
Jun Papa
  • 230 Points 100 badge 2x thumb
Posted 1 year ago
Photo of David Coglianese
David Coglianese, Embassador
  • 6,284 Points 5k badge 2x thumb
Unless you are trying to use stp for redundancy I would recommend elrp.
ELRP is very easy to configure and reliable. The only downside is that it lacks the dynamic enable when the loop condition is cleared.
Best of luck,
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,416 Points 2k badge 2x thumb
A very big disadvantage of using ELRP is that it blocks whole port instead of blocking specific vlan in which the loop was occured
Photo of Jun Papa
Jun Papa
Thank you Nick for the reply, the situation is like this, the iptv contractor requires this command in every tv port.
cisco command;
interface FastEthernet0/10
switchport protected
no ip address
spanning-tree portfast
i am looking for the same commande in extreme.
Thanks,
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
I think this does it
configure stpd "s0" ports link-type edge 1:2
Photo of Jun Papa
Jun Papa
i got this line;
 502.2 # configure stpd "s0" ports link-type edge 6,7
Error: Port 6 is not a member of STP domain s0
Error: Port 7 is not a member of STP domain s0
Error: Command aborted due to input errors, no changes made
Photo of Jeremy
Jeremy, Embassador
What version of code are you running? If you type show stpd ?... what stp domains are listed?
Photo of Jun Papa
Jun Papa
version 16.23
            MSTP Global Configuration:
MSTP Region Name        : 000496984141
MSTP Format Identifier  : 0
MSTP Revision Level     : 3
MSTP Digest             : ac:36:17:7f:50:28:3c:d4:b8:38:21:d8:ab:26:de:62
Common and Internal Spanning Tree (CIST)        : ----
Total Number of MST Instances (MSTI)            : 0
Name       Tag  Flags  Ports Bridge ID        Designated Root  Rt Port Rt Cost
s0         0000 D-----     1 8000000496984141 0000000000000000 -------       0
Total number of STPDs: 1                STP Flush Method: VLAN and Port
STP Filter Method: System-wide
Flags: (C) Topology Change, (D) Disable, (E) Enable, (R) Rapid Root Failover
       (T) Topology Change Detected, (M) MSTP CIST, (I) MSTP MSTI
Photo of Jeremy
Jeremy, Embassador
Here is my config
Photo of Jeremy
Jeremy, Embassador
enable stpd s0 auto-bind vlan Admin
enable stpd s0 auto-bind vlan AdminComputer
enable stpd s0 auto-bind vlan CiscoVideo
configure stpd s0 ports link-type edge 1:20
configure stpd s0 ports edge-safeguard enable 1:20
configure stpd s0 ports bpdu-restrict enable 1:20
Photo of Jun Papa
Jun Papa
thanks you... i got this
Stpd: s0                Stp: ENABLED            Number of Ports: 4
Rapid Root Failover: Disabled
Operational Mode: 802.1D                        Default Binding Mode: 802.1D
802.1Q Tag: (none)
Ports: 11*,13,14,23
Participating Vlans: Default,iptv
Auto-bind Vlans: Default,iptv
Bridge Priority            : 32768
Operational Bridge Priority: 32768
BridgeID                   : 80:00:00:04:96:98:41:41
Designated root            : 80:00:00:04:96:98:41:41
RootPathCost: 0         Root Port     : ----
MaxAge      : 20s       HelloTime     : 2s      ForwardDelay     : 15s
CfgBrMaxAge : 20s       CfgBrHelloTime: 2s      CfgBrForwardDelay: 15s
Topology Change Time           : 35s            Hold time        : 1s
Topology Change Detected       : TRUE           Topology Change  : TRUE
Number of Topology Changes     : 1
Time Since Last Topology Change: 19s
Topology Change initiated locally on Port 23
Topology Change last received on Port none from none
Backup Root               : Off         Backup Root Activated  : FALSE
Loop Protect Event Window : 180s        Loop Protect Threshold : 3
New Root Trap             : On          Topology Change Trap   : Off
Tx Hold Count             : 6
Participating VLANs:
VLAN                                     Tag    Number of Ports
          Ports
Default                                  1      1
          23(F)
iptv                                     14     4
          11*(D),13(F),14(D),23(F)
Flags: B-Blocking, D-Disabled, F-Forwarding, I-Listening, L-Learning
(Edited)
Photo of Jeremy
Jeremy, Embassador
Is it now working as expected?  Did you set auto-bind up for the VLAN's?  IDK if EZ-spantree is default on 16.xxx switches, but it is now for 22.xx.xx code.  You can install this as an XMOD to help your config.
https://github.com/extremenetworks/EXOS_Apps/tree/master/EZ_SpanningTree
