high CPU in X450 switch
  • Question
  • Updated 3 years ago
  • Answered
Hi everybody
we have X450 switch in our network  is facing  high CPU in the following process:
1-      ./hal
2-      ./FDB
3-       bcmRX
also when I ping to the IP of the switch I noted the bcmRX process increase
 I need to Know if this normal?
Mem: 246820K used, 7816K free, 0K shrd, 32580K buff, 72532K cached
CPU:  0.0% usr  100% sys  0.0% nic  0.0% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 4.11 4.11 4.08 3/182 2021
PID  PPID USER     STAT   RSS %MEM CPU %CPU COMMAND
1433     1 root     S     3316  1.3   0 26.3 ./fdb
1405     1 root     S <  11140  4.3   0 21.0 ./hal
1261     2 root     SW       0  0.0   0 21.0 [bcmRX]
2021  2020 root     R      780  0.3   0 15.7 top -d 3
1474     1 root     S     1920  0.7   0  5.2 ./bfd
1407     1 root     S     1596  0.6   0  5.2 ./nodemgr
1506  1505 root     S      764  0.3   0  5.2 ./telnetd -e
1409     1 root     S    31584 12.3   0  0.0 ./cliMaster
1415     1 root     S     5456  2.1   0  0.0 ./snmpSubagent
1536     1 root     S     4688  1.8   0  0.0 ./xmld
1561     1 root     S     3964  1.5   0  0.0 ./idMgr
1514     1 root     S     3920  1.5   0  0.0 ./etmon
1401     1 root     S     3732  1.4   0  0.0 ./emsServer
1472     1 root     S     3464  1.3   0  0.0 ./mcmgr
1413     1 root     S     3292  1.2   0  0.0 ./snmpMaster
1423     1 root     S     3288  1.2   0  0.0 ./vlan
1492     1 root     S     3076  1.2   0  0.0 ./pim
1466     1 root     S     2916  1.1   0  0.0 ./rtmgr update
1411     1 root     S     2848  1.1   0  0.0 ./cfgmgr
1501     1 root     S     2688  1.0   0  0.0 ./netTools
1499     1 root     S     2640  1.0   0  0.0 ./acl
regards,
Hasan
Photo of hasan issa
hasan issa
  • 154 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Its hard to tell just form this but you might have a loop on the network. I would suggest opening a case with GTAC to have this investigated further.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Hasan,
As Patrick stated, there is a possibility of a loop.
the process FDB would consume high CPU when there is too much learning happening in the switch. This is possible at the time of mac-movement.
Share the following output:
show log counters fdb occurred.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
I agree with Patrick, it seems that there may be a loop. The article linked below explains how to determine if there is a loop, and which ports it is on.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Which-commands-can-be-used-to-detect-a-loop
-Brandon
Photo of hasan issa
hasan issa
Hi everybody
Thanks for your support ,
Just for your information when I typing the command “ top” without press number 1   I see the CUP is normal but with press number 1 I see the CPU is high can somebody tell me why ?
 Also I typed the command L2stat and i found 5 Vlans  are copy a lot of packets to CPU after that  I used ELRP to detect  any loop in those Vlans but there is no any loop there .
Bridge interface on VLAN MW_MGMT_3511:
Total number of packets to CPU = 4628.
Total number of packets learned = 882939.
Total number of IGMP control packets snooped = 11364.
Total number of IGMP data packets switched = 104.
Total number of MLD control packets snooped = 0.
Total number of MLD data packets switched = 0.
Bridge interface on VLAN MW_MGMT_501:
Total number of packets to CPU = 3482.
Total number of packets learned = 39523.
Total number of IGMP control packets snooped = 21646.
Total number of IGMP data packets switched = 1094.
Bridge interface on VLAN KAEFER_Yanbu_L2VPN_HO:
Total number of packets to CPU = 149768.
Total number of packets learned = 391638.
Total number of IGMP control packets snooped = 23648.
Total number of IGMP data packets switched = 2854.
Bridge interface on VLAN SGS_DIA:
Total number of packets to CPU = 3760.
Total number of packets learned = 2209.
Total number of IGMP control packets snooped = 0.
Total number of IGMP data packets switched = 0.
Bridge interface on VLAN STS_2Mbps-DIA:
Total number of packets to CPU = 5499.
Total number of packets learned = 18835.
Total number of IGMP control packets snooped = 129.
Total number of IGMP data packets switched = 56.
* JUB_020.21 # configure elrp-client one-shot "MW_MGMT_3511" ports all print-and-log
Starting ELRP Poll . . .
# NO LOOP DETECTED # --- vlan "MW_MGMT_3511" elrp statistics ---
3 packets transmitted, 0 received, ingress port (nil)
 * JUB_020.22 # configure elrp-client one-shot "MW_MGMT_501" ports all print-and-log
# NO LOOP DETECTED # --- vlan "MW_MGMT_501" elrp statistics ---
 * JUB_020.20 #  configure elrp-client one-shot "KAEFER_Yanbu_L2VPN_HO" ports all print-and-log
# NO LOOP DETECTED # --- vlan "KAEFER_Yanbu_L2VPN_HO" elrp statistics ---
* JUB_020.23 # configure elrp-client one-shot "SGS_DIA" ports all print-and-log
# NO LOOP DETECTED # --- vlan "SGS_DIA" elrp statistics ---
* JUB_020.24 # configure elrp-client one-shot "STS_2Mbps-DIA" ports all print-and-log
# NO LOOP DETECTED # --- vlan "STS_2Mbps-DIA" elrp statistics ---
Regards,
Hasan
Patrick Voss, Alum
l2stats shows a count since the uptime on the switch or the last time someone cleared the counters (This information can't be found). Packets going to the CPU is normal. The problem is when you have a bunch of packets going to the CPU constantly.
I would recommend contacting GTAC moving forward considering there might need to be some diagnostic steps they can take that will require debug mode.
Hi Hasan,
Looking at the l2stats output, the count of packets learned has increased which is an indication of the too much learning in the switch. I still bet on the mac-movement happening in the switch or too much addition and deletion of the entries  happening in the switch.
example: Total number of packets learned = 391638.
As requested before, collect show log counters fdb occurred. Check for the counters of FDB.macadd, FDB.macdel and FDB.macmove.
Utilise the link below to configure mac-tracking and to identify the mac learning in the switch.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-MAC-tracking-in-EXOS/
Regarding your question regarding the top, can you please share the output while pressing 1 and without pressing 1 for our understanding.
Hope this helps!!
Keep us updated.
(Edited)
Photo of hasan issa
hasan issa
Hi Prashanth,
thanks for your support
I have configured the log for MAC-add , MAC-del and MAC-mov in the switch and I found a lot of packet related for add and delete MACs
below the log of FDB counters:
JUB_020.22 # show log counters FDB occurred
Component   SubComponent Condition               Severity      Occurred I Ntfd
FDB                      ArpDebugSummary         Debug-Summary    14638 N    0
FDB                      FdbDebugSummary         Debug-Summary  2067684 N    0
FDB                      FilterDebugSummary      Debug-Summary        9 N    0
FDB         MACTracking  MACAdd                  Notice              51 Y   47
FDB         MACTracking  MACDel                  Notice              49 Y   46
I need to know  we can prevent add and delete MACs in Vlans  also I need to know a huge of  adding  and deleting  MACs from Vlans will affect the switch
As your request in the Below the log of top command before press number 1 and during  press number 1
Before press number 1
 Mem: 247840K used, 6796K free, 0K shrd, 32804K buff, 73132K cached
CPU:  2.6% usr  1.9% sys  0.0% nic 94.3% idle  0.0% io  0.3% irq  0.6% sirq
Load average: 4.04 4.09 4.08 3/182 2301
 1433     1 root     S     3324  1.3   0  1.9 ./fdb
 1405     1 root     S <  11432  4.4   0  0.9 ./hal
 1490     1 root     S     2096  0.8   0  0.6 ./ripng
 2301  2300 root     R      780  0.3   0  0.6 top -d 3
 1413     1 root     S     3296  1.2   0  0.3 ./snmpMaster
 1407     1 root     S     1660  0.6   0  0.3 ./nodemgr
 1261     2 root     SW       0  0.0   0  0.3 [bcmRX]
 1409     1 root     S    31460 12.2   0  0.0 ./cliMaster
 1415     1 root     S     5460  2.1   0  0.0 ./snmpSubagent
 1472     1 root     S     3484  1.3   0  0.0 ./mcmgr
 1423     1 root     S     3336  1.3   0  0.0 ./vlan
 1466     1 root     S     2936  1.1   0  0.0 ./rtmgr update
 1411     1 root     S     2852  1.1   0  0.0 ./cfgmgr
 1486     1 root     S     2640  1.0   0  0.0 ./ospfv3
Load average: 4.18 4.14 4.10 3/182 2301
 1433     1 root     S     3324  1.3   0 30.4 ./fdb
 2301  2300 root     R      780  0.3   0 26.0 top -d 3
 1405     1 root     S <  11432  4.4   0 21.7 ./hal
 1492     1 root     S     3076  1.2   0  8.6 ./pim
 1261     2 root     RW       0  0.0   0  8.6 [bcmRX]
 1472     1 root     S     3484  1.3   0  4.3 ./mcmgr
 1413     1 root     S     3296  1.2   0  0.0 ./snmpMaster
 1056     1 root     S     2624  1.0   0  0.0 /exos/bin/epm -t 40 -f /exos/confi
 1484     1 root     S     2576  1.0   0  0.0 ./ospf
Regards,
Hasan
Hi Hasan,
Thanks a lot for your effort in collecting the requested outputs.
I see that you have added the log counters. So, if you issue the command show log, you will be able to know what mac addresses are added and deleted along with the port numbers and VLAN information.
See if you can find any pattern of a specific port or any specific mac-addresses. that should help a bit.
If you are using STP or any L2 loop prevention protocol, please check if there are any frequent topology changes. This could result in the FDB flush and forced re-learning.
Regarding the impact, it is hard to say unless we know the network completely. However it is not recommended to have high CPU in a switch. So, it would be good to sort this out.
I think this would be the right time to open a GTAC case with all this information as Brandon and Patrick suggested!
Thanks!
