High Fan Noise
  • Question
  • Updated 2 years ago
  • Answered
All these below switch  models make very loud fan noise. what is the solution to reduce the noise?
Summit X440-48t
Summit X440-48t
Summit X440-24p
Summit X440-48p
Photo of Sikander Shah
Sikander Shah
  • 712 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,210 Points 3k badge 2x thumb
Please refer to the X440 datasheet: Fan Speed and Acoustic Noise: http://learn.extremenetworks.com/rs/extreme/images/Summit-X440x-DS.pdf
Has the noise increased over time?
If it is excessively loud, I would suggest opening a case with GTAC to troubleshoot the fan issues.
It is optional to do a dB(A) test to verify the noise level.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,620 Points 5k badge 2x thumb
the general answer is to decrease the temperature. there are different fan speed levels based on temperature.
Z.
Sikander Shah
what temperature is recommended for all these switch mentioned above
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,026 Points 20k badge 2x thumb
as per the following article - below 30 (sensor temp) the fan will run on half speed and >30 on full speed
https://gtacknowledge.extremenetworks.com/articles/Q_A/On-a-X440-the-fan-speed-is-always-listed-as-1...
Sikander Shah
you mean to say that if it is (low temp below 30) switches run normally no noisy sound or if it is (high temp) switches make noisy sound.?
<30 = half fan speed
>30 = full fan speed
So the fan will allways run no matter what the temperature is.
But if the temperatur is greater 30 the fan will run with full speed = max noise.
Photo of modris bernands
modris bernands
  • 610 Points 500 badge 2x thumb
Offtopic - is there any loud specification about Extreme EPS-500?
I turn it off when I need to be in server room... :-)
