How assign speed in ports
  • Question
  • Updated 2 years ago
  • Answered
Hi ,
How to  assign manually 4mbps speed in particular ports in extreme 24 port switch?
Photo of isg helpdesk
isg helpdesk
  • 70 Points
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,214 Points 10k badge 2x thumb
The port speeds can only be set to 10,100,1000 or 10000 depending on the model and port capabilities. Are you looking to rate-limit the speed of a certain port?
If rate-limiting is what you are looking the article below should help:
Hope this helps!
Photo of Drew C.
Drew C., Community Manager
  • 36,016 Points 20k badge 2x thumb
Hi Vasanth, Welcome to The Hub!
I've made this thread public so that the community can respond.  There's nothing here requiring it to be private.
