how can i connect my VM to securecrt or putty ?
  • Question
  • Updated 2 years ago
  • Answered
I want to connect my VM through securecrt or putty but i didn't get a direct way.could you help me please ?
thanks
Photo of Ala Eddine Chhima
Ala Eddine Chhima
  • 414 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Zsolt
Zsolt, Alum
  • 120 Points 100 badge 2x thumb
What program are you using to emulate EXOS?
For example, if you are using VirtualBox you need IP connectivity between your PC and the VM. Then you can connect directly from your PC terminal.
Best Regards,
Zsolt
Ala Eddine Chhima
yes i enabled telnet i set adapter  to Wifi, assign port 1 and an ip adress to default vlan and it didn't work
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Did you set the adapters in vbox to allow promiscous?
Ala Eddine Chhima
yes i used the installation guide
Can you share your EXOS config and a screenshot of your vbox nic config?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
if you're using VirtualBox, I would recommend you to set Adapter 1 as "Host-only adapter" and use "VirtualBox Host-Only Ethernet Adapter". Choose adapter type as "Intel PRO/1000 MT Desktop".
You need to have in VirtualBox, in File > Preferences > Network a Host-only Network defined.
Set the IP address of the Mgmt vlan in that network as well, and you should be able to telnet/ssh/scp... from any tool on your laptop.
Photo of Matthew Helm
Matthew Helm, Employee
  • 1,852 Points 1k badge 2x thumb
Hope this helps.
