How can i get dhcp to work with opendaylight?
  • Question
  • Updated 2 years ago
  • Answered
Hi ,
I have a mininet topology setup which is linked to the ODL controller(beryllium) and i am able to see the flows/connections/nodes using YANG UI. I am trying to "discover" these nodes using the DHCP API on the northbound interface or by using an external dhcp server.The reason i am trying to do this is because i want to change the default IP addresses that are assigned to these nodes from the mininet.
Would appreciate help on anyone who can guide or provide materials on the same.
Thanks, Raghu
Photo of raghu nandan
raghu nandan
  • 70 Points
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,076 Points 5k badge 2x thumb
Raghu,
This post might help you do this.  Let us know if it worked for you?
https://techandtrains.com/2013/11/24/mininet-host-talking-to-internet/
