How can I import variable into an .xsf script ?
  • 2
  • Question
  • Updated 8 months ago
  • Answered
  • (Edited)
hello,
I want to import some variable (.py,.xml,...) into a .xsf script, it is possible ?
Many thanks in advance, alex
Photo of alex
alex
  • 120 Points 100 badge 2x thumb
  • anxious
Posted 9 months ago
  • 2
Photo of tknv
tknv, Employee
  • 382 Points 250 badge 2x thumb
Hi Alex,
'some variable' in .xsf, then when do you want to evaluate 'some variable' ?
or
evaluate 'some variable' then into .xsf script. Do you want to generate .xsf file?
Can you share more details?
Photo of alex
alex
Hi tknv,
Thanks for your help.
I finally find a solution, I import my variable which are stored in a .xsf by ftp to the switch, and i use a key to transport it to the principal .xsf.
alex
Photo of M.Nees
M.Nees, Embassador
  • 9,464 Points 5k badge 2x thumb
Can you give us a example what you try and how you solve it ?!
This is (maybe) interesting for me and all the other guys.
Thanks
Regards,
Matthias
Photo of alex
alex
I have a project to create a script that must detect if the
port of a switch is on or off, then find the MAC address of
the computer equipment that has just connected to the switch.
To finish, check if this address mac is part of the authorized
address and then put it in the vlan adapt.
Then, I created a file (.xsf) that informs all authorized macs that I import via FTP, and i use a key(load car key...) to transport
I hope I was understandable, and I apologize for my bad english.
If you have some question don't hesitate to ask me.
Alex
(Edited)
Photo of M.Nees
M.Nees, Embassador
Can you share an example ?
