How can I preform a password recovery on an Extreme 24e3 switch?
  • Question
  • Updated 2 years ago
  • Answered
Its believe its running 6.2 something.
I have the instructions below, but I believe that defaults the sw, I would rather try to keep the config if I could
  1. Connect switch to local serial console;
  2. Cold boot your device (power of the device, wait a minute, power on the device);
  3. In the very beginning of the boot process press Space to enter boot menu;
  4. Follow this procedure to remove any configuration and passwords:
    1. Press “1” to select primary boot image;
    2. Press “k” to erase current configuration;
    3. Press “d” to load default configuration;
    4. Press “f” to load switch with reset config;
  5. The result of this procedure is a switch with default login: admin and an empty password.
Photo of Jimmy
Jimmy
  • 650 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Jimmy, there is no way to perform a password recovery on S24e3 and keep the switch configuration.
The BootROM options clear all user/admin accounts + switch configuration to default.
