How can I print a message after executing an .xsf script?
  • Question
  • Updated 3 years ago
  • Answered
I am given some .xsf scripts that I just load using the
load script scriptName.xsf
The scripts do not print out anything. If possible I'd like to see a message printed after the execution like
Done!
Is it possible? It should be very simple but I cannot find any commands which print out messages in the manual. I tried
echo
but it is not supported. Is there a guide to .xsf scripting?
Photo of Ali Askari
Ali Askari
  • 272 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
I don't think that feature was added.  But when the script is done it gives your prompt back.
You can do the same thing with python.  and print ("Done!") at the end.
Photo of Drew C.
Drew C., Community Manager
  • 40,240 Points 20k badge 2x thumb
Ali, There's a guide out there somewhere.  I'll look for it - maybe someone can share it before I get to it.
Meanwhile, there's a lot of example scripts on our GitHub page that you might be able to borrow code from.
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/CLI_Scripting
Hope this helps!
easy python script.  Just save it as a .py file and run it like you would a .xsf.
exsh.clicmd('show vlan', True)
exsh.clicmd('show port conf no', True)
exsh.clicmd('show vlan "Default"', True)
print ("Done!")
(Edited)
Credit goes to Drew C.  Place these two lines at the end of your script
set var done "Done!"
show var done
X450G2-48p-G4.16 # load sc s.xsf
Done!
* X450G2-48p-G4.17 #
Photo of Ali Askari
Ali Askari
Thank you so much. That's exactly what I needed.
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
 you can also send info to log, like: create log entry "Test string..."
Jarek
