Fixed: How can I print (or export) a created map in Netsight 8
  • Question
  • Updated 10 months ago
  • Answered
  • (Edited)
I have created a kind of a "topology view" in netsight 8 and want to print or export it.
Is it possible?
I found some descriptions here but most of them for Netsight version 6 or 7?
Regards,
Axel
Photo of ar
ar
  • 516 Points 500 badge 2x thumb
Posted 10 months ago
Photo of ar
ar
I found an solution:
in Netsight 8.0.2.42 is it not possible but if you do an update to 8.0.3.46 then there is the export funktion available
