How can I reset summit 300-24 without using the console. No web GUI either.
  • Problem
  • Updated 2 years ago
  • Not a Problem
I am trying to use an extreme networks summit 300-24 for it's POE capabilities in installing IP surveillance cameras. I don't have a way to access the console and this may be the only time I ever use this switch. I need to clear the static IP address it has and turn off the DHCP function as it is conflicting with my modem/router combo. The IP address range the router uses is 192.168.0.1-253 and the summit switch is assigning it an IP address of 192.168.1.2 and I cannot access the camera or set up port for towing correctly. I guess I want to be able to use this as just a switch and clear it's IP address of 10.1.1.2. I see them in the client list in my router and I can go online with no problems. I just cannot access the GUI in the camera to set ports exact.can someone help???
Photo of Gary Bruce
Gary Bruce
  • 70 Points
  • frustrated
Posted 2 years ago
Photo of O'Connor, Brendan
O'Connor, Brendan, Employee
  • 350 Points 250 badge 2x thumb
Can you telnet or SSH to the switch ip address?
