How can I turn seamless roaming on V2110?
  • Question
  • Updated 1 year ago
  • Answered
Hello, everybody!
I have one V2110 controller (v10) and 10 APs. I need seamless roaming (mobility) for clients. How can I turned it on? The APs are 3805i, auth type is WPA-PSK.
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,408 Points 4k badge 2x thumb
Posted 1 year ago
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,110 Points 2k badge 2x thumb
Ilya,
roaming is seamless so you don't need enable special for this.
Regards
Umut
Photo of Umut Aydin
If you have more pair ( but you have only one controller so it's not needed)
then you need enable mobilty .
This can be done in the menu
Controller->Services->Mobility Manager
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
For PSK you need to design right coverage. The client should have a AP to what can roam. If there are too many APs it is bad. If there is no AP to roam it is bad.
(Edited)
Ilya Semenov
Thanks, gentlemen!
