How do I add, delete, modify a flow using the ODL API or Curl?
  • 2
  • Article
  • Updated 3 years ago
A question people frequently ask is "how to add a flow in OpenDaylight?".  This can be a little confusing because the UI for changing flows in DLUX only works with ADSAL in the Helium release and not MDSAL (which is what you will usually be using).
There are 2 workarounds.
  • If you want to use DLUX, you can enter flow information using the Yang UI.
  • If you want to use the API directly or send commands to the API using curl, you can follow the directions/examples below.
You can use the below curl commands to create/retrieve/delete a flow.  For more information on creating  flows and flow matches you can refer the below links.
https://wiki.opendaylight.org/view/OpenDaylight_OpenFlow_Plugin:End_to_End_Flows
https://wiki.opendaylight.org/view/Editing_OpenDaylight_OpenFlow_Plugin:End_to_End_Flows:Example_Flows
Program a  flow in config datastore:
Create a file L3Flow and configure flow parameters
curl -X PUT -d @L3Flow -H "Content-Type: application/xml" -H "Accept: application/xml" --user admin:abc123 http://10.127.13.240:8181/restconf/config/opendaylight-inventory:nodes/node/openflow:19701787512/table/0/flow/1
[openflow@10-127-13-225 ~]$ cat L3Flow
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<flow xmlns="urn:opendaylight:flow:inventory">
    <strict>false</strict>
    <flow-name>flow1</flow-name>
    <id>1</id>
    <cookie_mask>255</cookie_mask>
    <cookie>103</cookie>
    <table_id>0</table_id>
    <priority>20</priority>
    <hard-timeout>1800</hard-timeout>
    <idle-timeout>1800</idle-timeout>
    <installHw>true</installHw>
    <instructions>
        <instruction>
            <order>0</order>
            <apply-actions>
                <action>
                    <order>0</order>
                    <output-action>
                        <output-node-connector>22</output-node-connector>
                        <max-length>60</max-length>
                    </output-action>
                </action>
            </apply-actions>
        </instruction>
    </instructions>
    <match>
        <ethernet-match>
            <ethernet-type>
                <type>2048</type>
            </ethernet-type>
        </ethernet-match>
        <ipv4-destination>2.1.1.10/32</ipv4-destination>
    </match>
</flow>
* (Engineering) SW1.133 # show openflow flows
Total number of OpenFlow flows : 1
Total number of default flows  : 2
Flow name        Type     Duration (secs)  Prio              Packets
of_0             ACL                   12    20                    0
    Match  :  Ethernet Type       : 0x0800 (IPv4)
              IP Dst Address      : 2.1.1.10
    Actions:  output:22
    Timeout (secs/remaining secs) : hard:1800:1787,idle:1800:1787
    Cookie                        : 0x67
Retrieve a  flow in config datastore:
curl -X GET -H "Content-Type: application/json" -H "Accept: application/json" --user admin:abc123 http://10.127.13.240:8181/restconf/config/opendaylight-inventory:nodes/node/openflow:19701787512/table/0/flow/1
Retrieve a  flow in operational datastore:
curl -X GET -H "Content-Type: application/json" -H "Accept: application/json" --user admin:abc123 http://10.127.13.240:8181/restconf/operational/opendaylight-inventory:nodes/node/openflow:19701787512/table/0/flow/1
Delete a  flow in operational datastore:
curl -X DELETE -H "Content-Type: application/json" -H "Accept: application/json" --user admin:abc123 http://10.127.13.240:8181/restconf/config/opendaylight-inventory:nodes/node/openflow:19701787512/table/0/flow/1
Photo of Andrew Kinard
Andrew Kinard
  • 170 Points 100 badge 2x thumb
  • happy
Posted 3 years ago
  • 2
Photo of Sanjay kumar
Sanjay kumar
  • 60 Points
Hello, can you please elaborate the rest API body if a user needs to change the MAC/IP address of an incoming packet at switch ?
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Sanjay,  Sorry you haven't been replied to yet.  You can just add more actions like the ones i have below.  I included IP and MAC change actions.
MAC destination address change:
<action>
    <order>1</order>
    <set-dl-dst-action>
         <address>11:22:33:44:55:66</address>
    </set-dl-dst-action>
</action>
MAC source address change:
<action>
    <order>2</order>
    <set-dl-src-action>
    </set-dl-src-action>
</action>
IP source change:
<action>
    <order>3</order>
    <set-nw-src-action>
        <address>1.1.1.1</address>
    </set-nw-src-action>
</action>
IP destination change:
<action>
    <order>4</order>
    <set-nw-dst-action>
    </set-nw-dst-action>
</action>
(Edited)
Photo of Emad
Emad
  • 70 Points
Can you please reply to my next comment.
(Edited)
Photo of Emad
Emad
  • 70 Points
Based on previous comment, I try to use this xml, to force the flow to go to another destination, so I want to modify the destination address:
    <priority>33000</priority>
    <flow-name>Foo</flow-name>
    <match>
        <ethernet-match>
            <ethernet-type>
                <type>2048</type>
            </ethernet-type>
        </ethernet-match>
        <ipv4-destination>10.0.0.8/32</ipv4-destination>
    </match>
    <id>1</id>
    <instructions>
        <instruction>
            <order>1</order>
            <apply-actions>
                <action>
                   <order>1</order>
                   <set-nw-dst-action>
                   <ipv4-address>10.0.0.7/32</ipv4-address>
               </action>
            </apply-actions>
        </instruction>
    </instructions>
</flow>
however sending REST GET request to 10.0.0.8 is not redirected to 10.0.0.7 <br>
<u>sudo ovs-ofctl -O OpenFlow13 dump-flows br-int</u>: cookie=0x0, duration=63.453s, table=0, n_packets=0, n_bytes=0, priority=33000,ip,nw_dst=10.0.0.8 actions=output:8,set_field:10.0.0.7->ip_dst
Is there any source that I can refer for adding flows, this seems to be incomplete.
(Edited)
