How do I show the entire configuration without breaks on an Extreme Summit Switch? - similar to using terminal length 0 on Cisco
  • Question
  • Updated 2 years ago
  • Answered
The title pretty much says it all. I just need to know what the equivalent command on an Extreme switch is to terminal length 0 on a Cisco switch. I tried Googling this but I couldn't find the answer.
Photo of Trevor Jackson
Trevor Jackson
  • 302 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,240 Points 20k badge 2x thumb
Trevor Jackson
Perfect! That is exactly correct answer, and fast too.
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Trevor Jackson,
You can execute "disable clipaging" and then run the command "show configuration". It allows you to print continuously to the screen
Photo of David Rahn
David Rahn
  • 1,036 Points 1k badge 2x thumb
Disable clipaging
Show config....
Looks like I was late to the party.... what they said :-)
(Edited)
