How do I test traffic between switches?
  • 2
  • Question
  • Updated 2 years ago
  • Answered
I need to do a test traffic on a ring network.
The idea is to test by generating traffic if links are at least close to the expected nominal speed.
Whats I need to do this test? How?
Photo of Rodrigo Azevedo
Rodrigo Azevedo
  • 160 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Drew C.
Drew C., Community Manager
  • 38,610 Points 20k badge 2x thumb
Hi Rodrigo,
You can do this with the EXOS Service Verification Tool.
Here's some documentation that should help you get this working:
What are the requirements to use EXOS Service Verification Tool (ESVT)
Configuring the Service Verification Test Tool
(Edited)
Rodrigo Azevedo
Hummm... I understand EtherMAN,
Can I use iperf program to do this test?
Photo of EtherMAN
EtherMAN, Embassador
  • 6,688 Points 5k badge 2x thumb
we do that too and yes if you know how to use iperf this is a great way to test trough networks desktop to desktop... It really all depends on what you are trying to prove.  I can tell you from working at layer 2 ethernet for 19 years using Extreme they will always be able to get 100 % utilization out of any port or interface you use.  There is a huge difference in profiling a service or just checking continuity.
We are a metro carrier using Extreme 1600 switches about 80 or 90 EAPS rings ... 6000 or so active interfaces.... For a simple vlan built across the network traversing several rings/switches we just drop an ip/30 common subnet on the vlan on each side and do a ping test... if it works we have a complete service if not then there is an error in the configuration somewhere.
If we have to profile a service then we use either NIDS or test sets.
If we are trouble shooting customer throughput issues then IPERF is a good tool if they know how to use it or you still have to go back and use a test set and profile the service showing them you are not the problem....
Rodrigo Azevedo
Thanks EtherMAN,
One more question, in a ring network, do I have to do this traffic generator test switch by switch!?
Rodrigo Azevedo
This link is not avaiable. Is there a new link!?
Photo of Drew C.
I've updated my post to include new links, though the old one shouldn't have broken :(
Rodrigo Azevedo
Hi Drew C.,
How I could use a traffic generator for testing between switches? What I need to do this test?
Is there some setting that allows me to do this through the switch?
Photo of Drew C.
  • 38,276 Points 20k badge 2x thumb
The recommendations above for iperf or ESVT will work.  You could also use something like http://ostinato.org/, though I'm not familiar with it.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,528 Points 20k badge 2x thumb
Photo of Drew C.
Its not clear where to find the examples for how to configure it... which is on the next page.  Here's the link:
http://documentation.extremenetworks.com/exos/EXOS_All/Troubleshooting/t_configuring-service-verific...
Photo of EtherMAN
Rodrigo, chiming in here again since I brought up the test sets.  All you need is a common layer 2 vlan between your two test points in your network.. We us JDSU and Accedian.  In many cases some of the links we test may go through 8 or 10 switches with most being Extreme.  It could be a vman between all of these or it could be a simple vlan between point A and Point B.  It all depends on what kind of services you are trying to test... If you have a pair of test sets then you do not do anything different on the network side as one of the test sets will be generating the traffic and the other one is reflecting the traffic back so you can get Jitter, Latency, and packet lost... Look up RFC 2544 testing setups...
(Edited)
Rodrigo Azevedo
Thank you again,
I will read and do a test in the room.
One more question, with this test it is possible to pass by various switches until the end?
Photo of Drew C.
Depending on what you configure, sure.
