How do we change the IP address of Slave AP(WING AP-7522) from Virtual controller(WING AP-7522)?
  • Question
  • Updated 1 month ago
  • Answered
Is there any possibility to change the IP address of Slave AP from the Virtual controller
Photo of Prabhu.M
Prabhu.M
  • 412 Points 250 badge 2x thumb
Posted 1 month ago
Photo of Christoph S.
Christoph S., Employee
  • 3,410 Points 3k badge 2x thumb
Yes, and here's how:
1 - SSH into the the virtual controller and run the following commands:
>en
#conf t
#host <host-name>
#int vlan <vlan-id>
#ip address <A.B.C.D/M IP address>      (e.g. 10.0.0.1/8)
If you would like to retain the Zero config (secondary) IP address add the following line:
#ip address zeroconf secondary
#com wr
If you'd like to do this from GUI I would need to know if you're using the Swift or Enterprise UI.
Photo of Prabhu.M
Prabhu.M
We are using enterprise UI
On VC, go to Configuration >> Devices >> Device Overrides >> Select an AP from list >> Edit >> Interfaces >> Virtual Interfaces >> Select VLAN >> Edit >> IPV4 >> IPV4 IP addresses >> Uncheck: Use DHCP to obtain IP >> Enter static IP address in Primary IP address field >> Enable Zero Configuration: Secondary (optional) >> OK >> Exit >> Commit and Save.
