How do you Bar devices from a Wireless Manager WLAN
  • Question
  • Updated 1 year ago
  • Answered
Hi we broadcast a Guest SSID with a low value passkey, the idea is that most people can use it. However we have some folk who like to abuse this facility. Is there any way to bar users, using the mac address perhaps ?
Photo of Jamiea
Jamiea
  • 110 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Joshua Puusep
Joshua Puusep
  • 2,254 Points 2k badge 2x thumb
You can add MAC addresses to a blacklist on the controller by going to AP>Global>Client Management>Whitelist/Blacklist, however i'm not sure if there is a way to apply it to a specific SSID.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,004 Points 20k badge 2x thumb
Photo of Jamiea
Jamiea
Thank you I am using WM5.5. and cannot find the ap>global> etc
Joshua Puusep
Which controller and firmware are you using?  The setting i was referring to is found directly on the controller webUI, I'm not sure if you can do the same thing via wireless manager.
Photo of Jamiea
Jamiea
WM3700 3.41
Joshua Puusep
Apologies but I'm not familiar with that product.  I also can't seem to find the User Manual for it on the product page.  Maybe someone from Extreme can speak to this.
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,052 Points 4k badge 2x thumb
This is a Summit WM3700 Wireless LAN Controller running WiNG firmware.
(Edited)
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
try the following...
association-acl-policy CLIENT-BLACKLIST
permit 00-00-00-00-00-00 FF-FF-FF-FF-FF-FF precedence 1000
Add that to the WLAN config via the cli
use association-acl-policy CLIENT-BLACKLIST
Photo of Christoph S.
Christoph S., Employee
  • 2,560 Points 2k badge 2x thumb
In WiNG you could bar unwanted MAC addresses by going to Configuration >> Wireless >> Association ACL >> Add (to create a new ACL) >> Add row/s to create rules >> Save
Once done you must apply the ACL to the WLAN you'd like to use it on by going to Configuration >> Wireless >> Select the WLAN you want to apply it to >> Firewall >> Association ACL >> Select the ACL you created earlier >> OK >> Commit and Save.
Photo of Jamiea
Jamiea
Hi Thank you I tried this with 30 odd addresses but it killed the WiFi I had  00-00-00-00-00-00 FF-FF-FF-FF-FF-FF precedence 1000  Allow and the others were precenence 1-33
Photo of Shay Weir
Shay Weir
When you say it killed the wifi, please explain what happens .....
Photo of Shay Weir
Shay Weir
what does your association ACL look like? can you paste a copy for review?
does your association acl look something like this...
deny 78-0C-B8-F6-D3-9E 78-0C-B8-F6-D3-9E precedence 1
deny 1C-1D-86-70-0D-7E 1C-1D-86-70-0D-7E precedence 2
deny 28-C6-8E-10-79-12 28-C6-8E-10-79-12 precedence 3
For the "Allow All" rule please try using the following Starting and Ending MAC addresses: 00-00-00-00-01:FF-FF-FF-FF-FE
Photo of Jamiea
Jamiea
